Visitors: 107
Total: 107
42: My Account
43: Pictures
107: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- My '66 Baja
My '66 Baja
Post Post subject: Re: My '66 Baja
Posted: Thu Jan 31, 2008 01:48 AM
looks good!
loce the rhino seats, paint it primer and we can be the primer pair!
Sample
Sample
Posted: Mon Feb 11, 2008 11:49 PM
It got a coat of rustoleum flat black this morning.
Posted: Mon Feb 11, 2008 11:58 PM
nice, postt pics
I like rattle can paint jobs the best
Sample
Sample
Posted: Tue Feb 12, 2008 12:17 AM
joxracing wrote:
nice, postt pics
I actually bought a couple quarts of paint and used a cheap Harbor Freight spray gun. I will try to get a couple of pics later tonight/tomorrow.
Sample
Sample
Posted: Tue Feb 12, 2008 08:53 PM
Posted: Tue Feb 12, 2008 09:09 PM
Man Chris- you've been workin' hard on that thing! Been driving it much? I'm so tired of mine being broken- hopin' it'll be running again SOON!
Sample
Sample
Posted: Tue Feb 12, 2008 09:28 PM
Tony,
I have driven it around the block twice since I have had it. Smile
I just got the title paperwork yesterday.
I have gotta go through the brakes, for some reason I keep losing pedal pressure. I haven't found any lines leaking, so I am assuming I will have to replace a cylinder or two.
Posted: Tue Feb 12, 2008 09:32 PM
is it normal to have to pump your brake pedal to get it to feel stiffer?
looking good!
Posted: Tue Feb 12, 2008 10:03 PM
Jox, pumping is only normal on vehicles that require brake work.
Sample, can you see any bubbles come up through the reservoir when somebody pumps the brakes?
Posted: Tue Feb 12, 2008 10:15 PM
Get ready to get looked at funny when you go to MVD. Take that document that ITS sent you citing the Alabama law on registrations. MVD will look that up to verify it in their manual, but then you should be good to go. Just took awhile when I took mine down there- the lady said "wow- what a coincidence! This car was registered here in AZ recently, then it went all the way to Alabama, and now it's back!". I thought it better to NOT try to explain. Rolling Eyes
Sample
Sample
Posted: Tue Feb 12, 2008 10:21 PM
I am sure, with my luck, that it will be a big ordeal. Confused
Sample
Sample
Posted: Tue Feb 12, 2008 10:22 PM
Leather,
I will have to have my wife pump the brake pedal for me while I look, after she is off of the treadmill.
Sample
Sample
Posted: Wed Feb 13, 2008 02:59 AM
No, no bubbles when pumping the pedal.
Posted: Wed Feb 13, 2008 03:03 AM
Do you have the single or double-chamber master cylinder? Aren't cheap-o master cylinders problematic (but dirt cheap to replace) on these things?
Sample
Sample
Posted: Wed Feb 13, 2008 03:17 AM
It is a single. I thought about the master cylinder, but figured the brakes were probably in need of help. Maybe I will do all of it.
5 Admin_AzBaja 6800 Baja Bugs on Wiki need...
1568 mufasavnvmc 999912 Re: what did you do to...
285 MusicManiac 241521 Re: Baja sightings
0 Northmountainauto 1534 Shop Baja
