Latest: Curtis
Overall: 3613
Visitors: 137
Total: 137
02: Event Calendar
12: Event Calendar
18: Event Calendar
22: Event Calendar
32: Garage
45: Event Calendar
55: Event Calendar
67: Event Calendar
68: Event Calendar
111: Event Calendar
116: Event Calendar
119: Event Calendar
120: Event Calendar
124: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Dash options
Dash options
Post Post subject: Dash options
Posted: Fri Feb 08, 2008 04:46 PM
My current dash has two home-made sheet-metal dash inserts, and the right side only has one instrument hole. The left side has two switch holes gouged out of it, and the placement of those makes it impossible to add another instrument hole without it looking like an abortion. Sooooo, I need to either acquire some aluminum sheeting and make two new panels (or at least the left side), or come up with a better, pre-made solution.
I'm not a wizard fabricator- everything I make looks a lot worse than I wish it did. I see Chirco has a nice aluminum dash with 5 instrument holes- anyone ever use one of these? I like the price- anyone local carry something similar so I could get one TODAY????
Chirco aluminum dash- $40
Thanks for the help gents (and I use that term loosely, in case anyone may be offended..) Shocked
Post Post subject: Re: Dash options
Posted: Fri Feb 08, 2008 04:48 PM
PS- if the best option is to MAKE a new one, anyone know who carries small sheets of aluminum here in Mesa that would work to make something?
Thanks!
fireman
fireman
I installed one in a friends a couple of years ago and looked and worked great.
Rusty "fireman"
" With what we get, we can make a living; However with what we give, we can make a life"
Arthur Ash
fireman
fireman
Posted: Fri Feb 08, 2008 04:51 PM
You might try American Metals on Extension and Broadway. Or let me know what size and I can check with a friend that has a fab shop to see if he has anything.
Rusty "fireman"
Arthur Ash
Sample
Sample
Posted: Fri Feb 08, 2008 05:09 PM
Industrial Metal Supply
48th st. south of Broadway in Tempe.
I have some aluminum sheeting laying around.
Posted: Fri Feb 08, 2008 05:14 PM
I have some aluminum but its white. Will that work for you? I also have a template you can use to mark the dash piece out with.
Posted: Sat Feb 09, 2008 01:43 AM
BAP or Karls ?
Posted: Sat Feb 09, 2008 04:15 AM
I called Karl's today- they have the two-piece setup in stock, with one hole in the right side and a pair of holes on the left. They're only like $10 each, so I'll probably go get a pair in the morning. Hoping to hook up and run my motor this weekend, and install the gauges.
Posted: Sat Feb 09, 2008 04:54 AM
I just cut mine out completely as it was riddled with holes when I got it. I cut out some sheet metal and welded it in the big gaping hole. A little bit of Mar Glass at the edges, and VOILA!!!
New dash.
It wasn't all that hard, either.
I know they make fiberglass dashes too, made specifically to fit VW's. I think they just overlay the existing dash. I've never seen one installed.
No new posts VW Volkswagen & Baja Bug General Discussion Baja bug Dash
Looking for a carbon fiber dash
1 deputyrick 3280 Baja bug Dash
 Sat Jan 09, 2016 04:44 AM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion dash insert 6 blubaron66 5657 Re: dash insert
 Sun Jun 24, 2012 04:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW baja bug Exhaust options? 4 71VeeDub 8839 Re: VW baja bug Exhaus...
 Sun Nov 27, 2011 04:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 3262 Re: Need Help....Dash ...
 Thu Nov 10, 2011 07:55 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Solid Metal Dash
What year did they switch to plastic trim
3 MrSchaeferPants 4850 Solid Metal Dash
 Thu Mar 10, 2011 10:13 PM
