Visitors: 123
Total: 123
08: Event Calendar
22: Pictures
32: Pictures
39: Event Calendar
41: Pictures
45: Pictures
48: Pictures
52: Pictures
61: Event Calendar
64: My Account
69: My Account
87: Home
92: Home
97: Pictures
102: Home
103: Home
115: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Limiting Straps
Limiting Straps
cperry2704
cperry2704
Post Post subject: Limiting Straps
Posted: Tue Feb 05, 2008 03:13 AM
is there a way to put limiting straps on my baja since i dont have a cage yet?
Post Post subject: Re: Limiting Straps
Posted: Tue Feb 05, 2008 04:39 AM
Front or rear?
Posted: Tue Feb 05, 2008 11:25 AM
yes, bolt them eye to eye on the shocks.
cperry2704
cperry2704
Posted: Wed Feb 06, 2008 10:51 PM
sorry, was talking about the front, i have a 66
Posted: Wed Feb 06, 2008 11:57 PM
that is perefect run it eye to eye on the shock or evan better upper eye on shock to lower link pin. you can alos go to the upper link pin if you like.
May I ask, why are you after the straps? you having problems with your shocks or binding etc. or your tie rods hitting the pan...?
cperry2704
cperry2704
Posted: Thu Feb 07, 2008 02:06 AM
well, i am going to be welding in adjuster and raising the front end, with the help of 57baja sometime soon, and he sugested some kind of bump stop or limiting strap to keep the wheel travel from tearing apart the balljoints
Posted: Thu Feb 07, 2008 02:31 AM
if you have a link pin the only thing you have to worry about is the shock. If your car is a 66, I think you have a link pin, so nothing to worry about
cperry2704
cperry2704
Posted: Thu Feb 07, 2008 02:33 AM
no my car is a ball joint, but i just got a link pin beam fo free about an hour ago....just beam and spring, no arms or spindles or anything...so now i have to decide which to use
Posted: Thu Feb 07, 2008 02:35 AM
MY 66 HAS A BJ FRONT SWING OUT BACK
Thomas
Thomas
Posted: Thu Feb 07, 2008 02:42 AM
Have you thought about using the hook and pins like used on class 9 and some class 5s ? If anyone out there is willing to explain how you build and set these up I'd sure appreciate it. I need to set our buggy up with them.
No new posts VW Volkswagen & Baja Bug General Discussion How important are shock limit straps. Do I really need them? 8 Billy 3030 Re: How important are ...
 Fri Jan 05, 2007 05:07 AM
Billy View latest post
