Visitors: 148
Total: 148
24: Home
41: Event Calendar
50: Pictures
59: My Account
62: Pictures
88: Log Book
100: Event Calendar
101: My Account
107: Event Calendar
118: Pictures
133: Pictures
140: Pictures
143: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- race frame
race frame
69bapbaja
69bapbaja
Post Post subject: Re: race frame
Posted: Sun Jul 16, 2006 08:40 PM
when you weld you get hot and cold area's this become's "stress points"
when you re heat the area cherrie red and let it cool naturaly it looses the "stress points" and relaxes the metal.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
speedtrash
speedtrash
Posted: Mon Jul 17, 2006 11:31 PM
does steel build these stress points?
carpe diem
"sieze the carpe"
azhunter
azhunter
Posted: Mon Jul 17, 2006 11:53 PM
When you weld chromoly tubing, your fastening it together, there by removing the ability to "relax". it needs to relax due to being hot then cold in such small areas as only a small part is being affected. Bending chromoly tubing also requires heat de-stressing cuz when you bend it, your streching half of the tube more than the other half. chromoly tubing has a spring steel quality about it which makes it stronger, but also trickier to fabricate with. Did I loose you yet? Hope not. And i want to add, this is based on my own experience of fabrication and not factual.
speedtrash
speedtrash
Posted: Tue Jul 18, 2006 06:44 AM
is chromoly considered a steel?when welding with metals other than chromoly, will they build these stress points?
carpe diem
"sieze the carpe"
bajasam96
bajasam96
Posted: Tue Jul 18, 2006 06:51 AM
Chromoly IS steel, its just special
speedtrash
speedtrash
Posted: Tue Jul 18, 2006 06:53 AM
so would you have to stress relieve any steel frame you weld on?
carpe diem
"sieze the carpe"
bajasam96
bajasam96
Posted: Tue Jul 18, 2006 06:54 AM
no
speedtrash
speedtrash
Posted: Tue Jul 18, 2006 07:01 AM
sweet!
carpe diem
"sieze the carpe"
Posted: Tue Jul 18, 2006 07:44 AM
when you weld steel together it shrinks. on small frame assemblies you may want to go back and "relax" a few areas as the guys suggested, but with te proper design and assembly the welds should not FAIL at any point. tubing has to be "spliced" together properly in straight areas. joints ahve to be cleaned and formed to match the aligning angles to prevent gaps. if your assembly is layed out for a "dry" run, you would be able to find any "loose" ends before final welding.
also use a 230vac welder. the 120vac units splatter more. use gas (requires welder that is set up for gas) with the proper core for cleaner and stronger joints.
still need more info? go to home depot and get the weling book in the tools area.
or go here:
www.lincolnelectric.co...xcored.asp
www.muggyweld.com/steel.html
www.aussieweld.com.au/...page12.htm
www.thefabricator.com/...fm?ID=1030
(this one shows a race car frame)
www.ctsshifterkarts.co...turing.cfm
www.millerwelds.com/ed...efits.html
speedtrash
speedtrash
Posted: Tue Jul 18, 2006 08:27 AM
great sites (they'll soon come in handy), i have a lincoln-electric pro-mig 135. it has the gas outlet in back(all i need is a bottle to gas it) on most applications flux-cored does me well, but for a frame i'd drop the cash for a bottle. i've used shielding gas before, and damn i can make some pretty welds.
you know, writing this post reminds me how much i like to weld, and it sounds like we have some knowledgeable metal fabricators. we should have a custom project forum to discuss such things as fabricating parts, shortening/lengthening bajas, welding and similar. we could do this in the sandrail section but i think it'd be better to set-up another forum.
what do you guys think?
carpe diem
"sieze the carpe"
Say10
Say10
Posted: Tue Jul 18, 2006 03:34 PM
use argon, leaves sweet lookin welds. I ve done custom copper and aluminum work with it and it just looks bad ass.
speedtrash
speedtrash
Posted: Tue Jul 18, 2006 08:18 PM
yeah, what i've used in the past is half argon/oxygen, as far as shielding gas goes there's different mixtures for different metals. and they all allow for really nice welds.
carpe diem
"sieze the carpe"
tsutt
tsutt
Posted: Tue Jul 18, 2006 08:54 PM
what you really want to use for all general steel is a 75/25 mix.
No new posts Projects and Builds Vintage race junk donated it's parts 4 my desert toy.
Rebuilt this thread after I sold the frame
38 Azdrtdog 21662 Vintage race junk dona...
 Fri Apr 14, 2017 02:13 AM
No new posts VW Volkswagen & Baja Bug General Discussion Looking for a one piece race hood 11 CrisC918 6980 Re: Looking for a one ...
 Tue Feb 03, 2015 08:45 PM
49 wideopenmotorsports 31130 Pit Help Needed For Of...
 Tue Jan 08, 2013 05:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Desert Race Series in Az for 2012? 0 wideopenmotorsports 1500 Desert Race Series in ...
 Mon Nov 14, 2011 06:40 AM
No new posts Projects and Builds Navy nuke building a baja for Play/Race
133 navynuke 84319 Navy nuke building a b...
 Sat Jul 02, 2011 07:32 PM
ghettodish View latest post
