Visitors: 107
Total: 107
37: Event Calendar
52: Home
53: Home
61: Home
62: Home
78: Home
80: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Time to Rip and Tear
Jimmyjack
Jimmyjack
Post Post subject: Time to Rip and Tear
Posted: Sun Feb 03, 2008 06:58 PM
I'm gonna go tear the motor down today. I'm gonna bet the No.1 cylinder will have broken or bad rings and my crankshaft bearings are gonna be crap.
I'll try to take pics.
My buddy said he has a block that I can have. It's already machined for a 1776. He started a motor build but his bug got stolen and he never went back to it. SCORE!!!!! Cool
Jimmyjack
Jimmyjack
Post Post subject: Re: Time to Rip and Tear
Posted: Sun Feb 03, 2008 10:45 PM
Wow, that was pretty simple. I didn't see anything out of the ordinary except a layer of dirt covering each piston. About an 1/8 of an inch. I thought it was burned oil but when I scraped it it turned reddish. Like the dirt i found in the carb.
The cylinders weren't worn too badly, but the no.1 had some strange swirl marks on the inside near the top. None of the others had it.
The gap in the top ring was almost a 1/4 inch inside the cylinder. I removed it from the piston and slid it inside the cyl. I thought it would be tighter than that.
And lastly, how do I get the wrist pin out of the piston? I removed the clips but they won't slide out.
I'm going to get to the innards tomorrow.....
bajatink
bajatink
Posted: Mon Feb 04, 2008 12:26 AM
The wrist pins should just push out. They are a slip fit. I would bet that the dirt you mentioned has something to do with the difficulty you are having.
I would try some penetrating oil and a little force.
Posted: Mon Feb 04, 2008 12:55 AM
PB Blaster is your friend, get to know him. Do you plan on replacing the P & J's guess so if you are going to use the 1775 case.
Jimmyjack
Jimmyjack
Posted: Mon Feb 04, 2008 04:41 AM
They slide back and forth but only to a point. I didn't know if they were slotted or keyed.
Yeh, I'm gonna replace the pistons and jugs. I'm going to regring the crank and replace the cam.
I was surprised at how well the whole thing came apart......
I didn't mark the pushrods when thay came out. Hopefully that isn't too important. I'm gonna guess the cam comes with lifters and the push rods can't be too much money. I hope......
Posted: Mon Feb 04, 2008 04:44 AM
Put a socket on an extension and tap it with a hammer...It'll come out.
New User
2 Treeposter 1872 Time to let go....
 Wed Jun 21, 2017 11:23 PM
No new posts New Members New Memb. First time post 3 Maxxh2o 2761 New Memb. First time ...
 Tue May 27, 2014 10:32 AM
No new posts Projects and Builds It's Time! Summer Upgrades
17 Yummi 13758 Re: It's Time! Summer...
 Fri Nov 22, 2013 05:10 AM
Yummi View latest post
No new posts Projects and Builds It's about time... 3 Turbobaja 2679 It's about time...
 Fri Jan 25, 2013 03:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion West Side Pizza Thing Saturday June 18th Time 1:00PM
Yep, It is Pizza time for the west side.
10 AzBaja 8312 West Side Pizza Thing ...
 Sun Jun 19, 2011 07:11 PM
