Latest: xbluegto
Overall: 3573
Visitors: 158
Total: 158
07: Event Calendar
29: My Account
32: Pictures
34: My Account
38: Pictures
45: Event Calendar
92: Drivers
149: Pictures
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Baja bus
Baja bus
Post Post subject: Baja bus
Posted: Fri Feb 01, 2008 06:47 AM
Get your attention? I live in Flagstaff, it looks like I am moving to the valley in a couple weeks for a new job. I had a 72 beater bus a couple years ago that I did a poor man's baja job to. Fun little project. Problem was that at 7,000 feet, it had a hard time getting out of it's own way, let alone trying to climb anything. I had a 72 baja last year that I built from a standard beetle as well. Fun little buggy, but no room for the 5 of us, hence the baja bus idea again.
But, with the move to Phoenix, I thought I might give another bus a shot at being a baja bus again. Here are my thoughts. Feel free to chime in...
Pick up a bay window bus, preferably 68-71 due to the upright motor. I understand these engines better... Put 2.5" raised spindles in the front and re-index the rear torsion bars. Find some 27x8.5x14" tires for the rims, if it is a 71 or later, or 205/75/r15 tires if it has 15" rims.
The ground clearance won't be an issue, even at stock height. The weight is the problem. I think the lower elevation will help it run stronger though. No, it won't be jumped. But it would be cool to run around in the desert during the winter and spring/fall in it with the family. I also like the more agressive look.
Anyone know of a bus to be had?
Post Post subject: Re: Baja bus
Posted: Fri Feb 01, 2008 07:10 AM
Sounds like a neat idea- can't wait to see pics!
Posted: Fri Feb 01, 2008 01:06 PM
Check out craigslist, someone posted some adds here with a couple buses. Craigslist.org
on hold baja build
"when I nod my head, HIT IT"
Posted: Fri Feb 01, 2008 04:41 PM
Here is a later one for $500
phoenix.craigslist.org...49471.html
blood_red_baja
blood_red_baja
Posted: Fri Feb 01, 2008 05:07 PM
hmmmmmm roll over ever come to mind????
Posted: Fri Feb 01, 2008 05:58 PM
It won't be jumped. My last one didn't roll over either. I'm not into extremes with the loaf. I just like the more agressive look, and thought that it would be fun to do it right this time with a bay window.
blood_red_baja
blood_red_baja
Posted: Fri Feb 01, 2008 07:02 PM
when you do it, post some pics i'd like to see what a baja bus looks like
Posted: Fri Feb 01, 2008 10:41 PM
check out wayoutsalvage.com and look in projects
or check out the motivation for products thread on here or the straight axle 4wd thread on here
Posted: Sun Feb 03, 2008 05:26 AM
-Well, I picked up a 76 bus today. It has the 2000cc fuel injected engine. It is lowered with an adjustable front end and brackets for the rear end. Cool looking for now, but I want to put it to stock height, then raise it up a little.
Anyone want to assist in the lifting? Shoot, I'd pay someone to do it. Let me know. Thanks,
John-928-853-7628
Kev_n_AZ
Kev_n_AZ
Posted: Sun Feb 03, 2008 09:02 PM
www.baja.com/kombi/buspictures.htm
www.geocities.com/pimp...spics.html
sandlizrd.baja.org/bajabus.htm
George Washington
Posted: Mon Feb 04, 2008 05:55 AM
From what I read, the boomerang brackets on the rear of my bus that lowered it, can also be reversed to raise it above stock height. The front adjustable beam is an albatros. I think it can only go to stock height, but I don't know that for sure. Anyone know?
I'm torn between keeping it like it is, and fixing it up to sell, or reversing the lowered look and lifting it to make a baja bus. Sucks that my tires are shot, and I need to put some tires on it to get home to Flagstaff. I don't want to buy tires twice.
Posted: Mon Feb 04, 2008 10:00 PM
Turns out that the current bus will take too much to revert it back. So, I have a rat rod in the making. Someday, I'll get another bus and lift it.
Thanks.
Posted: Sun Feb 10, 2008 05:24 PM
Nope, looks like a guy in Tucson is going to do the work. I hope to have it done, painting, lift and all within a month. Yeehawwwwww
4 Admin_AzBaja 5720 Baja Bugs on Wiki need...
1568 mufasavnvmc 904793 Re: what did you do to...
285 MusicManiac 219192 Re: Baja sightings
0 Northmountainauto 283 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1565 Baja hiding in Chandle...
