Visitors: 157
Total: 157
02: Home
22: Event Calendar
29: Event Calendar
37: Event Calendar
51: Event Calendar
54: Event Calendar
67: Event Calendar
84: Event Calendar
85: Event Calendar
90: Garage
98: Event Calendar
117: Event Calendar
122: Event Calendar
127: Event Calendar
136: My Account
144: Event Calendar
150: Baja Forums
155: Event Calendar
156: Event Calendar
157: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Hedrock's 'vert project
1 2 3 4 5 ... 14 15 16
The following users give thanks for this topic Anonymous - Tue Mar 17, 2009 12:48 PM
Post Post subject: Re: Hedrock's 'vert project
Posted: Sun Jan 27, 2008 09:08 PM
Ah yes ok. After talking with Ron @ Safari Off-Road and going over my set up I find he has a tranny mount that corrects that. He has also recomended moving the tranny back, putting the drive flange 1" ahead of the axle flange. Mine is sitting 6" ahead, putting an extra angle in the mix. Thanks for the info and the pics, did you move the nose also?
on hold baja build
"when I nod my head, HIT IT"
Posted: Sun Jan 27, 2008 09:12 PM
kcnaz wrote:
Hey do me a favor and measure between your cv flanges right and left. Is there a difference? Mine is offset.....just curious.
i thought it was just me that had a problem...
only i moved my to the right to correct it...
Posted: Sun Jan 27, 2008 09:29 PM
Yes... Bascially the same way. Here are a couple of pics of the mount I used.
Posted: Sun Jan 27, 2008 09:32 PM
Yes sir, luckily I am not tied down yet. Thanks for the great info. Its raining today and I am looking at options. Thanks again. Looks like ya didn't go back? No?
on hold baja build
Posted: Sun Jan 27, 2008 09:36 PM
I moved mine to the right also... Wink
Posted: Sun Jan 27, 2008 09:41 PM
Nope ... I dont think you have to with 3x3's. I guess you could but I don't know how much I would have gained.
Posted: Sun Jan 27, 2008 10:09 PM
The axle flange is now at 15 degrees back on a horzional from the tranny output flange and 12 degrees down. I figure as the trailing arm cycles up and is nearing the elevation of the output flange that 15 degrees will increase. Make sense? Using T-2 cv's would stress them while under load...........at around 17 degrees when the car is under load and compressing.
Moving the tranny back would relieve that part of the cv load.
Correct me if I am wrong......
on hold baja build
Posted: Tue Jan 29, 2008 05:51 AM
Pulled the body off tonite to start adding some more bracing and begin welding. Hopefully I can get the inside of the body cleaned up next week and get it put back on for the last time.
Here are a couple of pics without the body...
Get'in closer... Very Happy
Posted: Tue Jan 29, 2008 05:56 AM
Looks good Hedrock, doing a great job.
Posted: Fri Feb 01, 2008 04:39 AM
I agree........very nice.
on hold baja build
Posted: Fri Feb 01, 2008 04:58 AM
Leather, Here is a pic of the upper mount we talked about. Does this help clear up any fog? Wink
DRUMMOND
DRUMMOND
Posted: Fri Feb 01, 2008 07:53 PM
How did you get the windshild frame to look so good I am doing the same thing and have no idea what to do to get that clean of a look ?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Sat Feb 02, 2008 01:21 AM
Lots and lots of patients ... and several 4 1/2" grinding discs
DRUMMOND
DRUMMOND
Posted: Sat Feb 02, 2008 02:28 AM
Do you have a close up pic of what the inside corners look like?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Sat Feb 02, 2008 04:47 AM
I'll take one in the AM.
1170 Dalton 277064 My 69 project
 Wed Dec 06, 2017 02:38 AM
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1545 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 52497 Project II
65 PaDan 49714 Re: My project
 Thu Feb 11, 2016 07:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6877 Re: new project
