Visitors: 106
Total: 106
47: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Link Pin Woes
Link Pin Woes
Post Post subject: Link Pin Woes
Posted: Thu Jan 31, 2008 09:23 AM
I thought I might share this with everyone. A few weeks ago I was driving home from work and I heard a some real nasty grinding sounds coming from my front end. I'll remind everyone that I have recently rebuilt my ride from the ground up and have less than 500 miles on it since everything (I MEAN EVERYTHING) was replaced. Anyway, to make a long story short, I'm running those HEAVY DUTY link pins with the lock nuts that hold them in place:
One of the lock nuts had spun off and was gone. The other three had loosened up. My brake caliper was rubbing on the link pin heads and the whole front end sounded like it was going to explode! I tightened the remaining three and drove (Oh so carefully...)25 miles home.
Since then, I bought 8 narrow hardened nuts at OSH and double nutted the damn things on with Loctite. They shouldn't go anywhere now.
...Just an FYI for those who are going to be using those pins.
Post Post subject: Re: Link Pin Woes
Posted: Thu Jan 31, 2008 02:12 PM
Wow I would have thought it was all good after tightening them up, good info, thanks.
on hold baja build
"when I nod my head, HIT IT"
Posted: Thu Jan 31, 2008 05:50 PM
Guess time to dbl check all hardware.
Posted: Fri Feb 01, 2008 04:26 AM
What happens is the lock nut tightens up against the link pin carrier. Of course the trailing arm travels up and down, rotating as it goes. The tighter the nut, the more pressure is rotating the nut against the link pin carrier. When I double nutted it, I tightened the first nut hand tight (kinda like a wheel bearing nut). and tightened the second jamb nut up real tight to the first one, using two wrenches.
Posted: Fri Feb 01, 2008 07:08 PM
Thanks for the info. I have the same thing on mine.
Posted: Fri Feb 01, 2008 07:42 PM
Me too Shocked
32 AzBaja 30161 Get the www.AzBaja.com...
 Fri Feb 03, 2012 11:36 PM
1966baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin Conversion 8 Bryman042 6073 Re: Link Pin Conversio...
 Thu Jun 23, 2011 12:41 AM
Bryman042 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need a rebuild on my link pin beam 2 wideopenmotorsports 2483 Re: Need a rebuild on ...
 Wed May 18, 2011 01:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion ball joint or link pin? 3 thext94 6780 Re: ball joint or link...
 Sat Apr 10, 2010 08:57 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin stiffer front torsion leafs 6 nvlandshark 4529 Re: Link Pin stiffer f...
 Sat Jan 16, 2010 04:03 PM
nvlandshark View latest post
