Latest: Nrd123
Overall: 3578
Visitors: 119
Total: 119
02: Event Calendar
12: Event Calendar
27: Event Calendar
49: Home
88: Home
109: Pictures
111: Event Calendar
Leatherneck's rail
Post Post subject: Leatherneck's rail
Posted: Wed Jan 30, 2008 06:32 PM
Might as well start mine.
Appletree or Whitehill frame (modified), 1914. turbo cam. 45 dell,T03/4 turbo,6rib stock tranny, 2 X 3 rear arms, 27mm torrsion, dual KYjelly shocks. 33 X 12.50 rear tires. Front beam 8 over with 4 X 2 1/2 arms Fox 12 coilovers, race braced (?)
For those who do not know, this is me. I know you thought I would be taller.
When I got tired of how it looked and ran this is where I started.
Before the frame change.
That is about it. I have tore this thing down 3 or 4 times I forget, never happy with it, maybe one day Rolling Eyes
Posted: Wed Jan 30, 2008 10:50 PM
Nice car Leather
Posted: Wed Jan 30, 2008 11:00 PM
Very nice!
Now, if I could just get some monetary support,,,,well, I'd settle for help with the labor, I'd happy as a pig in?????
twistedsmily
twistedsmily
Posted: Wed Jan 30, 2008 11:22 PM
nice lookin rail you got there
Posted: Thu Jan 31, 2008 04:54 AM
The front looks just Bad as... For Mykul that is MadMax evil look Smile
Posted: Thu Jan 31, 2008 05:44 AM
Hell YA! Twisted Evil
Posted: Thu Jan 31, 2008 05:56 AM
Thanks guys, hopping that it will be able to hang in the desert scene. I was thinking I had to much skid plate, Hedrock says not enough. Sad
Posted: Thu Jan 31, 2008 02:14 PM
Nice ride Leather, I like it!!
on hold baja build
"when I nod my head, HIT IT"
Posted: Thu Jan 31, 2008 08:16 PM
Yea I cannot wait to get out there and do some riding with you guys.
You guys who have moved your tranny left or right to center the drive flanges, did you all move the foreward mount or left it at an angle?
Here is my forward mount where I notched it for clearance. Sorry not really good pictures.
Here is where I am going to cut and lower the tranny in the saddle
edit: got some more done.
Got the mount dropped down.
The frame horn notched.
Yea don''t bust on my welding, well unless ya need to.
And how close the drive flange is, lowered it down about 3/4 of an inch which helps on the CV angle.
Close but does not touch the frame horns Very Happy
Posted: Fri Feb 01, 2008 04:31 AM
"You guys who have moved your tranny left or right to center the drive flanges, did you all move the foreward mount or left it at an angle?"
I am moving mine over but not down. the nose cone mount will be going away.
we have talked B-4
on hold baja build
Posted: Fri Feb 01, 2008 04:45 AM
That is still cool.
Posted: Sun Mar 02, 2008 02:29 AM
Got some time today to work on the rail so this is what I got done.
I honed out the cylinders and painted the jugs.
Since I busted one ring I figured I would replace them all that way I know they are good.
Engine needs something so I should get busy.
Got the pistons stuffed in the jugs, drilled a hole in the Teflon plugs
Time to start putting cylinders on.
Finished with putting all the cylinders on so time for the heads, first put on pushrod tubes.
Second take off pushrod tubes and put bottom cooling tin and tubes back on.
So tubes on, tin on put the heads on and torque.
Done with the engine for today, unpacked what the UPS present guy dropped off
Posted: Sun Mar 02, 2008 04:36 AM
Is that the key to the "DARKSIDE"?
on hold baja build
VIN70
VIN70
Posted: Sun Mar 02, 2008 04:40 AM
what did you use to seal the jugs to the case? why drill a hole in the teflon buttons?
Posted: Sun Mar 02, 2008 06:02 AM
Ahhh the darkside, Laughing Hopefully it will make it run just a wee bit better. Get some of the heat out of the engine.
Copper sealant, you drill a hole to let the oil out, the oil will screw with the weight of the pistons.
No new posts VW Volkswagen & Baja Bug General Discussion My VW Rail vacation 13 azdesertrat87 6299 Re: My VW Rail vacatio...
 Mon Jul 22, 2013 07:32 PM
30 dogknott 23582 another newb, just bou...
 Sun Jun 26, 2011 06:11 PM
dogknott View latest post
No new posts VW Volkswagen & Baja Bug General Discussion So you think your rail flys??? 1 perrib 1851 So you think your rail...
 Wed Jan 26, 2011 05:06 AM
thext94 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front tires on a rail 1 Vipon 1493 Re: front tires on a r...
 Wed Jun 16, 2010 02:51 AM
No new posts Projects and Builds Rail resurrection 4 Thingster 2761 Re: Rail resurrection
 Thu May 13, 2010 01:45 AM
Thingster View latest post
