Latest: hulkbaja
Overall: 3594
Visitors: 148
Total: 148
02: Event Calendar
15: Home
26: My Account
28: Home
29: Text Menu
37: Home
42: My Account
45: Home
52: Event Calendar
61: Contact Admin
63: Video Wall
90: Links
95: Event Calendar
96: Drivers
97: Pictures
99: Event Calendar
104: My Account
110: Event Calendar
126: Home
137: News Letter
143: Contact Admin
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- AZ350X's '59
AZ350X's '59
1 2 3 4
Post Post subject: AZ350X's '59
Posted: Tue Jan 29, 2008 05:03 AM
Well, I'm not the one that built this, but for as long as it's been sitting in my garage torn apart, I SHOULD have! I bought it 6 months ago, and I've only driven it once- home from the PO's house. Crying or Very sad Can't wait to get it back together and on the road.
It's a '59, has a 1915 with an 002 trans. 3x3s, 930 CVs, rear disc brakes. Front suspension is stock ( Crying or Very sad ), like-new 33's and 30's front and rear on "Centerline" wheels. Caged, Race ? front seats, harnesses, 10-gallon fuel tank up front, 1 piece front end. I just had the motor rebuilt- it has CB 044 heads, Engle 110 cam, and a Dellorto 40 on top. I guess that's about it- here's the pics...
Post Post subject: Re: AZ350X's '59
Posted: Tue Jan 29, 2008 05:05 AM
Oh yeah- I waxed it after these pics- the paint looks mo' better now. I also polished the wheels up, and BAJAWARRIOR recovered those nasty front seats awhile back, so they look NEW!!!
Posted: Tue Jan 29, 2008 05:19 AM
Nice looking bug Smile Smile Smile ... What is the line that is going into the exhaust (or looks like it does).
Posted: Tue Jan 29, 2008 05:36 AM
It feeds the carb that feeds the exhaust Rolling Eyes
That is a sharp looking Baja, if I could make another suggestion is put you fuel filter up by your fuel tank, you have room that way you have less connections that can fail close to your spark producing devices.
Posted: Tue Jan 29, 2008 08:19 AM
The fuel line is going in to the base of the carb- it sure does look like it's feeding the exhaust though, eh? (Actually, I was told by the PO that it's an afterburner...) Laughing
Sample
Sample
Posted: Tue Jan 29, 2008 09:58 AM
I like that car. Looks like you picked up a good project. Wink
1966 Baja.
Posted: Tue Jan 29, 2008 10:35 PM
this is prob. my fav. baja on here
even tho i love all of them
Posted: Thu Jan 31, 2008 04:57 PM
Thanks for the props. I better get a move-on on getting it back together and on the road (and off the road!), or the VP/CFO is gonna try and make me sell it! NOOOOOOO!!!
Sample
Sample
Posted: Thu Jan 31, 2008 05:13 PM
I will give you $25 for it.
Laughing
Posted: Thu Jan 31, 2008 05:46 PM
Can't wait to see it in action, is that the original color? Sample that is a insult, $25 come on, how about a $100? Have you done anymore with setting the rear torsion, or going to wait for the engine in before?
Posted: Fri Feb 01, 2008 05:29 AM
At this point, I think I'm going to hang the motor, and see what that does to the axle angle. That way hopefully, I can adjust it one last time and be done (ha ha, right?). I just want to be DONE!
Posted: Fri Feb 01, 2008 01:14 PM
Good looking car, I like the way the front is cut.
on hold baja build
"when I nod my head, HIT IT"
Posted: Mon Feb 04, 2008 02:22 AM
SUPER BOWL SUNDAY- UPDATE- So, a buddy of mine came by today. We got lower engine mount studs lengthened sufficiently, and the motor is hanging! Also, you may recall, my axle angle was sitting at 28-29* (my CV's were of course binding), so we pulled the torsions apart and reindexed them. I came down one spline (we think) at the inboard end. I'm sitting at 19-20* axle angle now it looks like. Car sits a little lower now, but I've still got around 17" of clearance in the rear. The shocks are off, and it's strange that I can actually push down on the motor and the suspension actually gives some now- before, the preload was so high that we'd HANG on a pipe sticking out of the back of the car, and couldn't get the suspension to droop at all. If this setup seems too soft, I may have to pull it apart AGAIN and maybe go up one spline at the outboard end (springplate). Seems like that should put me somewhere higher than now, but now as high as it was. Gonna have to put one of the CVs back together- it came apart during disassembly. But, the axles are ready to go in, the rear shocks (after I repaint them), patch the floor, put in the interior, install the gauges, then hook up and fire the motor.
One step closer... Very Happy
Posted: Mon Feb 04, 2008 02:37 AM
az350x wrote:
1FASTHOE wrote:
tony, what size torsion bars did you install ? (mm)
I stayed with the stock long torsions.
az350, your problem is not the angle but the torsion size, you will need to go up to at least a 27mm and I would say maybe 30mm the stock size is 23mm and ya have to remember it has seen alot of road time in 49years even if it is NOS it is still to small.
Posted: Mon Feb 04, 2008 06:26 AM
Sounds really cool. It's exciting when you start getting close. Hope to see some more pix soon.
No new posts Projects and Builds AZ350X suspension/brake upgrade- call it DONE
[ Go to pageGo to page: 1 ... 6, 7, 8 ]
116 az350x 83247 Re: AZ350X suspension/...
 Fri Dec 19, 2008 02:48 AM
abcprint View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Here is before and after pics of az350x seats 6 bajawarrior 2721 Re: Here is before and...
 Mon Sep 10, 2007 04:49 AM
kevin View latest post
