Visitors: 103
Total: 103
16: Pictures
19: Pictures
22: Pictures
37: Pictures
72: Pictures
82: Event Calendar
90: Pictures
96: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- i think im in over my head.....
blood_red_baja
blood_red_baja
Post Post subject: i think im in over my head.....
Posted: Mon Jan 28, 2008 11:29 PM
the only gauge that works in my 69 is the speed-o-meter, nothing else, and i cant get my turn signals to work either. are there relays for them or fuses? ughhhh.
Post Post subject: Re: i think im in over my head.....
Posted: Tue Jan 29, 2008 01:10 AM
fuses...
Posted: Tue Jan 29, 2008 01:27 AM
Check the fuses, check the connections. Do you have a multi-meter, if not do you have a way of buying or borrowing one?
blood_red_baja
blood_red_baja
Posted: Tue Jan 29, 2008 01:55 AM
lite bulbs are good, and those funny lookin fuses are good also. this sucks
Posted: Tue Jan 29, 2008 02:00 AM
Don't just look at the fuze's, take them out, look on the contact area for corrosion or possibly a bent ear, something that does not make good contact, then start at that wire inspect it, look for breaks or slices, trace it to where it goes to, once there check that connection, maybe swipe the fingernail file from the wife or girlfriend and go over the contact points. Take your time, maybe time to look at a rewire, that is doable and gives you a chance to upgrade the antique wiring.
Posted: Tue Jan 29, 2008 02:06 AM
yea, none of my lights- head,tail, anything work
they only work when i put on the flashers, and thats just the taillights
Sample
Sample
Posted: Tue Jan 29, 2008 02:19 AM
Turn the turn signal switch on. Get a cheap HF or HomeDepot volt meter. Put positive probe on one side of fuse, put black probe to ground. Should have pulsing voltage. Put the positive on the other side of the fuse, should be pulsing too. If not you have a bad fuse or connection.
OR take out the fuse and ohm it out with the meter.
Or, you can make a long test cable, connect one end to the battery, then one end to the output side of the fuse, see if you have a steady light on.
Or it may be the relay, or a connection at the relay. Or it could be the switch assembly or a connection there.
1966 Baja.
Posted: Tue Jan 29, 2008 02:23 AM
i dont know, who ever did my wiring i think is blind
half of it is aftermarket and the 30% is stock and the rest is like household crap
shpuz
shpuz
Posted: Tue Jan 29, 2008 03:51 AM
100% of mine is home made and everything works Very Happy but then again, the guy who did it was an electrical tech. im having a problem with my blinkers too. its not the wiring tho, i can spin my blinker lever al the way around the wheel Shocked
Quote::
oldfart
oldfart
Posted: Wed Jan 30, 2008 07:55 PM
just a tip.....run a extra ground wire from each light mounting stud to a clean bare metal spot on the body. Use crimped eyelets at the least. This of course especially if you're running them on fiberglass fenders. I'd do it before diving any deeper. Old VW wiring does strange things searching for a ground. Just a word of advice.
No new posts VW Volkswagen & Baja Bug General Discussion Vw Frame Head bent 5 azdesertrat87 5101 Re: Vw Frame Head bent
 Tue Jan 25, 2011 07:25 PM
No new posts Events and Get Togethers World Wide baja snow run.......(plannin a head) 7 kevin 2725 Re: baja snow run........
 Fri Oct 06, 2006 07:26 PM
kevin View latest post
