Visitors: 107
Total: 107
16: Event Calendar
20: Event Calendar
33: My Account
35: Pictures
75: Home
76: Home
77: Event Calendar
82: Event Calendar
88: My Account
90: My Account
102: Pictures
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Hedrock's 'vert project
1 2 3 4 5 ... 14 15 16
The following users give thanks for this topic Anonymous - Tue Mar 17, 2009 12:48 PM
Post Post subject: Re: Hedrock's 'vert project
Posted: Sun Jan 27, 2008 08:08 PM
Ah yes ok. After talking with Ron @ Safari Off-Road and going over my set up I find he has a tranny mount that corrects that. He has also recomended moving the tranny back, putting the drive flange 1" ahead of the axle flange. Mine is sitting 6" ahead, putting an extra angle in the mix. Thanks for the info and the pics, did you move the nose also?
on hold baja build
"when I nod my head, HIT IT"
Posted: Sun Jan 27, 2008 08:12 PM
kcnaz wrote:
Hey do me a favor and measure between your cv flanges right and left. Is there a difference? Mine is offset.....just curious.
i thought it was just me that had a problem...
only i moved my to the right to correct it...
Posted: Sun Jan 27, 2008 08:29 PM
Yes... Bascially the same way. Here are a couple of pics of the mount I used.
Posted: Sun Jan 27, 2008 08:32 PM
Yes sir, luckily I am not tied down yet. Thanks for the great info. Its raining today and I am looking at options. Thanks again. Looks like ya didn't go back? No?
on hold baja build
Posted: Sun Jan 27, 2008 08:36 PM
I moved mine to the right also... Wink
Posted: Sun Jan 27, 2008 08:41 PM
Nope ... I dont think you have to with 3x3's. I guess you could but I don't know how much I would have gained.
Posted: Sun Jan 27, 2008 09:09 PM
The axle flange is now at 15 degrees back on a horzional from the tranny output flange and 12 degrees down. I figure as the trailing arm cycles up and is nearing the elevation of the output flange that 15 degrees will increase. Make sense? Using T-2 cv's would stress them while under load...........at around 17 degrees when the car is under load and compressing.
Moving the tranny back would relieve that part of the cv load.
Correct me if I am wrong......
on hold baja build
Posted: Tue Jan 29, 2008 04:51 AM
Pulled the body off tonite to start adding some more bracing and begin welding. Hopefully I can get the inside of the body cleaned up next week and get it put back on for the last time.
Here are a couple of pics without the body...
Get'in closer... Very Happy
Posted: Tue Jan 29, 2008 04:56 AM
Looks good Hedrock, doing a great job.
Posted: Fri Feb 01, 2008 03:39 AM
I agree........very nice.
on hold baja build
Posted: Fri Feb 01, 2008 03:58 AM
Leather, Here is a pic of the upper mount we talked about. Does this help clear up any fog? Wink
DRUMMOND
DRUMMOND
Posted: Fri Feb 01, 2008 06:53 PM
How did you get the windshild frame to look so good I am doing the same thing and have no idea what to do to get that clean of a look ?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Sat Feb 02, 2008 12:21 AM
Lots and lots of patients ... and several 4 1/2" grinding discs
DRUMMOND
DRUMMOND
Posted: Sat Feb 02, 2008 01:28 AM
Do you have a close up pic of what the inside corners look like?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Sat Feb 02, 2008 03:47 AM
I'll take one in the AM.
1199 Dalton 339016 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3375 Project Purple People ...
88 Dirtjunkie 62664 Project II
65 PaDan 57013 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8326 Re: new project
