Visitors: 169
Total: 169
08: Event Calendar
42: Home
43: Contact Admin
46: Home
48: Home
63: Home
86: Home
90: Home
91: Drivers
92: Text Menu
102: Drivers
111: Event Calendar
125: Home
149: Home
150: Baja Forums
153: Home
154: Contact Admin
156: Home
158: Home
162: Baja Forums
164: Event Calendar
165: Text Menu
166: Home
168: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Help!!!
Help!!!
cperry2704
cperry2704
Post Post subject: Help!!!
Posted: Sun Jan 27, 2008 07:26 AM
ok two questions:
#1 i need to replace the gasket on my steering box, does anybody sell just the gasket? and also what type of grease do they pack the steering box with?
#2 how in the world do you get the door hinges off the door? looks like they are riveted on or something!
Post Post subject: Re: Help!!!
Posted: Sun Jan 27, 2008 07:42 AM
Gear oil for the steering box, I think it's the same stuf you pu in the transaxle.
Posted: Sun Jan 27, 2008 08:01 AM
I would just put some Molly grease in it, just don't over pack it. As far as the gasket, make your own, not a abundance of replacement parts. The Doors, I have no clue.
Posted: Sun Jan 27, 2008 03:55 PM
Heres the deal. You can just use a sealant on the top of the steering box, no need for a gasket. From the factory the boxes did have oil in them however the bottom seal tends to leak at drop of a pin. Soooo heres the fix. Look on the top cover of the box and you will find 2 plastic plugs. Take one of the plus out and tap it and screw in a grease fitting (the cover is aluminum so its easy to do). Take the other plastic plug and poke a pin hole in it, this way when you grease it it will come out the hole when full. I have been doing this since the 80s and it works great!!!
Posted: Sun Jan 27, 2008 05:39 PM
Could he not just put grease inside, sealant on top and install the cover. How many times does one add grease to there Steering box, most people with a grease nipple will fill it till it shoots out of some orfice which now means a seal has been breached which means if something got out, something can get in.
Posted: Sun Jan 27, 2008 05:50 PM
The doors unbolt from the car. There are 3 bolts on each of the hinges inside the door seem. At least one of them should have a round plastic plug over it. The bolts are a large Philip's head and pretty difficult to break loose with out stripping them, so use the right screwdriver tip and a manual impact driver (Harbor Frieght has them cheep). The other side of the hindge is welded/rivited to the door. Personally it's not worth messing with. If there is a problem on that side replace the doors.
cperry2704
cperry2704
Posted: Sun Jan 27, 2008 08:47 PM
looks like ill be replacing the door then, the bottom hinge is rusted shut, and wont budge!
i have a 66...what year bugs have a compatable door?
Posted: Sun Jan 27, 2008 11:21 PM
Yes you can just pack it with grease and seal it up if you want.
cperry2704
cperry2704
Posted: Mon Jan 28, 2008 11:35 PM
ok sounds good, my steering box is missing those two plastic plugs, do they sell these? or any ideas how to plug these two holes?
