Visitors: 97
Total: 97
05: Event Calendar
20: Event Calendar
35: My Account
74: Event Calendar
81: Event Calendar
91: My Account
94: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Decent front suspension
1 2 3 4
Post Post subject: Re: Decent front suspension
Posted: Sat Jan 26, 2008 05:01 AM
Wow, beams are cheap and it's only 4 large bolts undo the stearing coupler at the steering box and the brake lines. The beam comes out as a unit. you can do all the work with it of the car then bolt it back on.
Posted: Sat Jan 26, 2008 05:05 AM
how long would that take?
Posted: Sat Jan 26, 2008 05:15 AM
i got 16' shox on it right now, how big could i go
and do they have to be coilovers?
cperry2704
cperry2704
took me llike 15 minutes, and im new at the baja thing...its super easy
Posted: Sat Jan 26, 2008 05:17 AM
How fast can you remove 4 bolts? and the then to for the stearin coupler and 2 brake lines. it's real quick.
As for swaping the parts to a new beam it will take a little longer. but your beam is done, check for rust all over the front part that holds your beam. if that has rust on it you will need to get it fixed. as this is the back bone of the car.
realy?sweet!
do they make bj 6" overs?
Posted: Sat Jan 26, 2008 10:29 PM
so to switch to a link pin you have to cut the frame head off and weld on a link pin head?
Where do u fonf link pin heads?
Posted: Sat Jan 26, 2008 10:34 PM
Off a bug that has a link pin front end or fab up your own.
Posted: Sun Jan 27, 2008 12:02 AM
Heres what I did
cut off the Ball joint here and added some back up strips to reinforce the weld area
Then I cut off a link pin from a donor and left if with 4" to push the front forward.
LINK PIN FINISHED
on hold baja build
"when I nod my head, HIT IT"
Posted: Sun Jan 27, 2008 12:08 AM
sweet....nice job keith Cool
Posted: Sun Jan 27, 2008 12:25 AM
Looks very nice... Can't even tell Wink
Posted: Sun Jan 27, 2008 02:24 AM
so you have to take the body off im guessing....
Posted: Sun Jan 27, 2008 02:41 AM
I don't think you have to, having the body off made the overhead welding easier as there was none. It also made squaring it up easier, if ya do it make marks somewhere on the pan before you cut to use a reference point later. Check the alignment before you weld and as u weld.
on hold baja build
Posted: Sun Jan 27, 2008 02:44 AM
how long did this take you?
is this really necessary for trail riding. muddin, small jumps etc..
Posted: Sun Jan 27, 2008 02:58 AM
Start to finish about 8 hours...........no you don't need it.
on hold baja build
1 2 3 4
No new posts Projects and Builds Suspension Help 5 RDMINAZ 3914 Suspension Help
 Mon Jul 18, 2016 03:06 PM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 1988 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja suspension upgrade on All Girls Garage TV show May 3rd. 4 BugZyla.com 4542 Baja suspension upgrad...
 Tue May 13, 2014 12:35 PM
Front End question
12 ButchW 6712 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3133 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
