Visitors: 111
Total: 111
03: Event Calendar
18: Event Calendar
47: My Account
78: Pictures
81: Event Calendar
94: Event Calendar
98: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Roll Cage Tubing Caps
Post Post subject: Roll Cage Tubing Caps
Posted: Mon Jan 21, 2008 06:54 AM
I'm kind of geeky, I'm sure, but I absolutely HATE the look of an unfinished roll cage tubing end. They look goofy, and sooner or later water collects inside and then the roll cage fills with rust and looks even worse. Some guys shoot paint inside to disguise the rust, but it's still in there, rusting away from the inside out.
I thought of a trick several years ago to finish off those unfinished ends of your bumpers that I thought I'd share:
Make a trip down to Pep Boys and get the cheapest steel (not brass) freeze plugs to match your tubing size, usually 1-1/2". Taper the ends of your tubing and the freeze plugs with a die grinder and weld them on. Grind them even when you're done, and fill any imperfections with Bondo. Sand them smoooooth and paint to match.
Presto!
They have a real nice finished and rounded look and it all cost you about $1.00. The ends are actually a ton stronger than if left open, too. How can you beat that?
Post Post subject: Re: Roll Cage Tubing Caps
Posted: Mon Jan 21, 2008 07:04 AM
Wow. It looks a bit scratched up after ten years, but you get the idea.
Jimmyjack
Jimmyjack
Posted: Mon Jan 21, 2008 04:16 PM
Hell yah, theres nothing a grinder and bondo can't make shine! I made a bumper for my blazer years ago. Even over the engine noise I could hear a whistle when I was driving dwn the road. Turned out it was the open ends of the tube. Took some old flat stock and cut it into squares, tacked it to the ends of the bumper tubes, ground to match the tube and used black silicone.
Posted: Mon Jan 21, 2008 05:33 PM
My bumpers came with push in ends that I welded in.
Posted: Tue Jan 22, 2008 01:12 AM
thats a great lil' idea 57... Wink
MOCRAWLER417
MOCRAWLER417
Posted: Sat Feb 02, 2008 04:31 PM
I buy lots of tabs and end caps from www.aa-mfg.com They sell a ton of fab parts at pretty good prices.
25 Kreed 26287 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
18 Dirtjunkie 6644 Official 2016 Hassaymp...
 Tue Nov 08, 2016 02:49 AM
42 wideopenmotorsports 14365 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 03:14 AM
No new posts Events and Get Togethers World Wide ROLL CALL: Hassayampa Play Day 2013 - November 9th & 10th
November 9th & 10th
46 wideopenmotorsports 29564 ROLL CALL: Hassayampa ...
 Tue Nov 12, 2013 09:14 AM
No new posts VW Volkswagen & Baja Bug General Discussion tubing notcher recommendations 13 chrispy56 8000 tubing notcher recomme...
 Tue Apr 03, 2012 06:31 PM
brokenparts View latest post
