Latest: strike77
Overall: 3575
Visitors: 100
Total: 100
01: Home
23: Event Calendar
32: Event Calendar
39: Event Calendar
40: Event Calendar
42: Event Calendar
91: Pictures
95: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Ball joint to Linkpin
cperry2704
cperry2704
Post Post subject: Ball joint to Linkpin
Posted: Mon Jan 21, 2008 11:26 PM
how much is there to do when switching from ball joint to linkpin front end? is it just the beam itself and the frame head? or is there more to it?
can someone help?
Post Post subject: Re: Ball joint to Linkpin
Posted: Mon Jan 21, 2008 11:57 PM
Do you want to maintain the stock lengrh of the car? I added 4" to the length of mine in the process of switching over.
on hold baja build
"when I nod my head, HIT IT"
cperry2704
cperry2704
Posted: Tue Jan 22, 2008 12:11 AM
yes i want to keep the stock length
Posted: Tue Jan 22, 2008 02:05 AM
I can build you a link pin beam that will bolt into ball joint frame head, but I dont have the spindle carriers yet to make the geometry work perfect, but it will still work. I am still trying to fing a reliable machine shop to produce the carriers.
cperry2704
cperry2704
Posted: Tue Jan 22, 2008 02:09 AM
well i have a 66 which is balljoint, and i have a small buggy i bought, and just realized it has a linkpin front end, so thats where im at...weather to swap em or not?
if i swap em, what else will i need? if anything?
Posted: Tue Jan 22, 2008 04:58 AM
I swapped mine over to king & link from ball joint. All the books say you need a new frame head, because the torsion tube spacing is wider on the ball joint than on the king and link set-up. I did it without changing the frame head. I just got out my Sawzall and my welder and made the damn thing fit. When I did it, I switched to long travel, and used a 6" wider beam. I also switched the steering out to to rack and pinion. Aside from a complete front end (spindle to spindle including shocks), you may need to modify or use a different steering box if you're going to stick with the stock set-up. You may also have to modify the actual steering shaft, too, as it will be slightly different geometry, as the steering box bolts to the upper torsion tube. It's all do-able, and if you have decent fabrication skills, it can probably be done without buying anything except welding wire and spray paint, assuming you have a working parts car that you're swapping stuff from.
Hope that helps.
cperry2704
cperry2704
Posted: Tue Jan 22, 2008 05:43 AM
thanks for the help, think im going to keep the ball joint front for now, atleast get in driving for a bit, then mess with the front end
Posted: Mon Jan 28, 2008 03:26 AM
hey bugzyla, i need one of them link pin , ball joint beams
how much ya think?
Posted: Mon Jan 28, 2008 03:56 AM
$300 for stock width with any length shock towers, $350 for widened beams up to 12 over with any length shock towers.
Posted: Mon Jan 28, 2008 04:28 AM
sounds good to me, i will deff. think about it
No new posts VW Volkswagen & Baja Bug General Discussion Wide Ball Joint front end? 5 Darn_Near 7298 Wide Ball Joint front ...
 Wed Sep 07, 2011 08:12 AM
Darn_Near View latest post
No new posts Events and Get Togethers World Wide Joint TRAl and USFS event and ride. 0 perrib 1827 Joint TRAl and USFS ev...
 Mon Jan 31, 2011 04:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Ball joint issues
Trying to remove the ball joints from the torsion arms.
13 ChuckD 4691 Ball joint issues
 Wed May 12, 2010 08:06 AM
Baja_Blue View latest post
No new posts VW Volkswagen & Baja Bug General Discussion ball joint or link pin? 3 thext94 6962 Re: ball joint or link...
 Sat Apr 10, 2010 08:57 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion FIRST (NEVER HAPPENED) AZ/SoCal Joint Adventure - PICS ADDED
This would be kinda fun...
60 57baja 21242 FIRST (NEVER HAPPENED)...
 Tue Feb 09, 2010 05:44 PM
57baja View latest post
