Visitors: 152
Total: 152
14: Home
52: Home
68: Home
101: Home
127: Event Calendar
130: Home
131: Home
132: Pictures
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- one last problem, please help....;-(
nube_w_1970baja
nube_w_1970baja
Post Post subject: one last problem, please help....;-(
Posted: Thu Jan 17, 2008 08:24 AM
alright fella's, i almost have everything worked out. i really appreciate all the help and advice that you have given me.
i just need to know one last thing, hopefully.
so i got the heads and pistons and everything else hooked up and connected and tightened down, checked and double checked.
so then it turns on and runs, somewhat...
initially i couldn't get all the way off the clutch in first gear.
maybe compression, timing or carb adjustment.
bad gas?
got new gas.
got out of the driveway:)!!!!!
so now i'm finding out, as i let off the clutch i really have to rev it up and double clutch it a couple times till i get up to 2,000/2,500 rpm. then it goes like a bastard:)
i know i'm getting close to being able to show off my bug, it's just this one really small thing that's keeping me.
so what i need to know is what are the possibilities of it being carb, timing and compression.
and what are common symptoms of these things that aren't working right?
good times,
jeff
hopefully the first weekend in february i'll be able to go out to that meet in superstition mall.
Post Post subject: Re: one last problem, please help....;-(
Posted: Thu Jan 17, 2008 02:41 PM
Sounds like possibly timing.
Posted: Thu Jan 17, 2008 04:29 PM
timing. and check the spark plugs I ran into the same problem. I trash the bosch plugs and put in autolight plugs it ran great. thank's Daryll for the tip Very Happy
Posted: Thu Jan 17, 2008 05:14 PM
Replace the fuel filter ,one more thing your title of "one last problem, please help....;-(" if you think this is your last problem I have some water front property that I will sell ya. One last problem, that was funny!
Posted: Thu Jan 17, 2008 06:40 PM
Autolights, really? Confused
Sample
Sample
Posted: Thu Jan 17, 2008 06:49 PM
Mine does the same thing. Really have to rev to keep it from stalling while letting out the clutch.
I have yet to put a timing light on it.
1966 Baja.
nube_w_1970baja
nube_w_1970baja
Posted: Fri Jan 18, 2008 01:48 AM
timing is supposed to be about 7.5 retarded as the crank with the marks on the timing wheel turns counter clock-wise correct?
i'm still confused on how to get this right...
Posted: Fri Jan 18, 2008 04:10 AM
No it's clockwise. 7.5 if the dist is stock. most of us are runnoing a 009 dist. You have to time them different. I think its 24 degrees BTDC @ 3000rpm put I need to doulble check.
Posted: Fri Jan 18, 2008 04:50 AM
yeah, autolights ? what happened to ngk's ?
Posted: Sat Jan 19, 2008 01:39 AM
Is your carb too big? Do you have a vacuum leak? your choke open or is it closed? Floats set to high etc.
Posted: Sat Jan 19, 2008 01:59 AM
Well just to clear it up it was the Bosch PLATINUMS that bajawarrior had in his motor. The Bosch Supers work fine as well as the autolites or NGKs. The Bosch Platinum plug is not a good one to run with a standard (points or HEI) ignition, they work best with a high output ignition such as a MSD or DIS ignition.
Posted: Sat Jan 19, 2008 08:01 AM
Yeah, it sounds to me like a timing problem to me, or a problem with the idle circuit in your carb. I see that you are running a Weber Progressive and not with a 009 distributor? You kow the vaccuum advance needs to be hooked up with a stock distributor. Otherwise, it will not advance properly to meet the engine's needs. One other thought: I would set TOTAL advance at 30 degrees BTC with a timing light (at 3000 to 3500 RPM's) once you verify that your vaccuum circuit is operating properly. VW's tend to run best right in that range.
As far as the idle circuit goes: All VW carbs that I'm familiar with have a mixture screw for the idle circuit. I've never played with a Progressive, but my 44's have 'em. The idle control circuit usually controls the fuel until about 2500 RPM's. If it's out of whack, you'll have those symptoms. The rule of thumb is back the screw out a bunch until it idles OK, then slowly turn it in until you first start to hear it misfire. You have to pay real close attention. When it first misfires, STOP, then backit out 1/4 to 1/2 a turn again. This will at least get you in the ballpark, even though I don't know the exact specs for your carb.
One other thing you might try: Sometimes crap gets stuck inside a carburetor fuel passage. Take the air cleaner off and run the engine at 3000 RPM's and cover the air intake tightly for a few seconds with your hand on top of the carb to force the engine vacuum to suck out whatever crap maybe in the fuel passsage or jet. Sometimes this will magically fix a problem that nobody else has ever seen. I know from experience that this works sometimes.
Try those things. If they don't work, there's other things that we'll get into.
nube_w_1970baja
nube_w_1970baja
Posted: Sun Jan 20, 2008 03:03 PM
the distributer isn't stock or a bosch 009. it does have centrifugal advance on it.
i'm thinking i'm going to have to start inviting ppl over to help me out with this.
anybody like beer?
maybe next sunday (27th) i could grab a couple cases and figure this out...
the car is out in Fountain Hills, so, let me know what you guys are thinking...
good times,
jeff
fatalifeaten
fatalifeaten
Posted: Mon Jan 21, 2008 12:23 AM
did we forget about clutch adjustment? Sounbds like that may be out a bit...
--Harlan Ellison
nube_w_1970baja
nube_w_1970baja
Posted: Mon Jan 21, 2008 12:34 AM
that's why i'm making the offer of inviting a couple ppl over with beer being the bait.
i know i need help, so if anyone is interested they can PM me
No new posts VW Volkswagen & Baja Bug General Discussion I have a problem
Can anyone help me
8 PaDan 5554 Re: I have a problem
 Tue Jul 12, 2011 06:33 AM
Rickman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rack and pinion problem
Steering backwards?
5 Bunnyhunny425 5485 Re: Rack and pinion pr...
 Sat Apr 30, 2011 06:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion 1960 vw baja surging/wheel hop problem
baja problems
24 hayduke 9533 Re: 1960 vw baja surgi...
 Wed Aug 04, 2010 02:40 AM
hayduke View latest post
No new posts VW Volkswagen & Baja Bug General Discussion NEW PROBLEM YAY :)
clutch or transaxle
4 seanoflinn1 2447 NEW PROBLEM YAY :)
 Mon Jun 14, 2010 08:51 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion welding problem... 4 Brettucks 2623 welding problem...
 Sat Apr 17, 2010 05:59 AM
Brettucks View latest post
