Latest: ecthemc
Overall: 3567
Visitors: 112
Total: 112
72: Event Calendar
79: Event Calendar
107: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Pinto 2.3 adapters
Pinto 2.3 adapters
Post Post subject: Pinto 2.3 adapters
Posted: Fri Jan 11, 2008 02:32 AM
How much $ are ford pinto 2.3L engine adapters for the vw transaxle, if they even have them
looking for a new engine for baja, possibly a pinto powerplant
What modifacations whould i have to do to the pan, bumpers,etc... to fit a pinto in there
Or corvair engines?
Post Post subject: Re: Pinto 2.3 adapters
Posted: Fri Jan 11, 2008 02:35 AM
Try Kenedy or Essenies(sp?) For the adapters. Or check Craig's list.
Posted: Fri Jan 11, 2008 02:44 AM
i need a link
remember i live in nothern mich., theres never parts on the web
Crash
Crash
Posted: Fri Jan 11, 2008 03:34 AM
heckermachine.com
esslingerracing.com
kennedyeng.com
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Posted: Fri Jan 11, 2008 04:00 AM
Your car an IRS, if not then ur gonna need to up grade, Bus tranny 3 rib or 6 rib.
If it is IRS type 1, then ur gonna need to up grade, Bus TYPE 2 tranny, 3 rib or 6 rib.
Brake up grade, your gonna have to stop it.
A little BFH (AZBAJA) work to get the engine to fit.
Throddle cable mods.
What have I missed?
Chirco parts to finish off the mate.
clutch
Pro Grip Heavy Duty Clutch Disc, 200mm [CPR141100] $36.95
Pressure plate 200mm
Kennedy, 2600lb Early Pressure Plate [KEPSTAGE3E] $109.95
Crash
Crash
Posted: Fri Jan 11, 2008 06:21 AM
It depends on how you drive. We have run a n/a 2.3 against a bug tranny and it worked okay. Of course we had to drive a bit smart and not try to do wheelies.
-Mark
Mark Johnson
Posted: Fri Jan 11, 2008 07:26 AM
I'be been running a bug IRS in my baja too, but I do have a super diff and heavy duty side plates and a light presure (2200lb) plate that acts like a fuse. We found out on the dyno that it starts to slip at 88 HP it could be a good or bad thing but I would rather burn up a clutch than bust a transaxle. It will still out pull a VW motor up a hill etc. but it's no rocket ship my buddys old 1600 was quicker just did not have the torque to clib nd turn larger tires.
Posted: Sat Jan 12, 2008 01:22 AM
dont forget radiator placement...
the adaptor will run you about 350, 400 bucks. keep watching craigslist, even in your area there's rails around...
Posted: Sat Jan 12, 2008 01:58 AM
nevermind i'll stick w/ vw
Posted: Sat Jan 12, 2008 02:12 AM
DOH! Can't believe I forgot the cooling part. LOL
Posted: Sat Jan 12, 2008 02:16 AM
gave up already.... Question
Posted: Sat Jan 12, 2008 02:28 AM
im 14 i aint pumpin that much cash into my baja, besides my whole pan is like rusted
lucky im builden a full cage welded into the new 1/2" steel floor boards:0
Sample
Sample
Posted: Sat Jan 12, 2008 04:03 AM
1/2" steel floor boards? That is some heavy stuff right there.
1966 Baja.
Posted: Sat Jan 12, 2008 04:04 AM
shit did i say half, i meant quarter
Posted: Sat Jan 12, 2008 04:10 AM
1/4" steel floor boards? That is some heavy stuff right there.
No new posts VW Volkswagen & Baja Bug General Discussion wheel adapters 6 primedaddy 2556 Re: wheel adapters
 Fri Oct 10, 2008 02:29 AM
No new posts VW Volkswagen & Baja Bug General Discussion pinto adapter
23 saltyslug 14983 Re: pinto adapter
 Sat Oct 28, 2006 04:42 AM
cactusdog View latest post
