Visitors: 113
Total: 113
23: Event Calendar
48: Event Calendar
79: Event Calendar
104: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- lift
lift
Jimmyjack
Jimmyjack
Post Post subject: Re: lift
Posted: Tue Jan 08, 2008 06:24 AM
Longer shocks for sure. I made a 2" spacer for mine to compensate. Also my neighbor told i could remove one or two of the springs and maintain the lift but soften the ride.
Can anyone else verify this? I think it makes sense and sooner than later I'm gonna hafta replace my ball joints......
Posted: Tue Jan 08, 2008 06:46 AM
Instead of removing the springs ... I think you would be better off replacing a couple of the solid (one piece) springs with some of the split (2 piece) springs.
Jimmyjack
Jimmyjack
Posted: Tue Jan 08, 2008 06:57 AM
So take out the bigger springs and replace them with the smaller? I thought they were all the same size....
cperry2704
cperry2704
Posted: Tue Jan 08, 2008 07:10 AM
what springs are you talking about? i dont think ive seen any
Jimmyjack
Jimmyjack
Posted: Tue Jan 08, 2008 07:16 AM
You won't. They run the length of the tubes from arm to arm. There are about 10 or so stacked all together to make a bunch. Like a bunch of popsicle sticks. They're clamped in the middle ( where you cut and turn the tubes) and the arms twist and down on the ends of the springs. When you cut and turn you cos the springs to twist, causing more of a bind and the car will raise. That's where you get the stiff ride from.
cperry2704
cperry2704
Posted: Tue Jan 08, 2008 07:19 AM
ok that makes alittle more sense, i wasnt clear on how cutting and turning makes the car rise......so when cutting and turning, the spring need to be removed from the beams?
Jimmyjack
Jimmyjack
Posted: Tue Jan 08, 2008 03:07 PM
Nope, they stay in place.
cperry2704
cperry2704
Posted: Tue Jan 08, 2008 11:56 PM
so you cut around the bem not completely through it im guessing?
Jimmyjack
Jimmyjack
Posted: Wed Jan 09, 2008 01:52 AM
Yes, BUT I talked a friend of mine at work today and described what I did. He laughed and said " a 1/4 turn? More like a 1/4". He told me a 1/2" at most. What do some of you more experienced guys say about this????
Cos if that's the case I'm screwed. I'm not gonna recut and turn mine. I'll just get another front end and start over.
25 Kreed 21770 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
Front End question
12 ButchW 6138 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2120 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 1 elryano 1824 Re: body lift
 Thu Apr 12, 2012 02:21 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super Beetle lift kit 5 ghettodish 7479 Super Beetle lift kit
 Sun Mar 27, 2011 12:18 AM
ghettodish View latest post
