Visitors: 160
Total: 160
04: Home
101: Event Calendar
107: Event Calendar
118: Event Calendar
125: Home
134: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Anyone know how to?
Anyone know how to?
Post Post subject: Anyone know how to?
Posted: Sat Jan 05, 2008 03:57 AM
does anyone know how to put on those rubber empi waterproofing kits for your dist. cap and coil? those things are frustrating!
Post Post subject: Re: Anyone know how to?
Posted: Sat Jan 05, 2008 08:17 PM
Yes they are. So much so that I don't use one and haven't had any problems...
...but I live in AZ and we only see rain once in a blue moon.
insanehounds
insanehounds
Posted: Sat Jan 05, 2008 09:00 PM
i just use di-electric grease on the terminals, unless you sink the engine in water or mud this will usually help prevent any problems.
Go ugly early in the night, that way it doesn't turn to a 2:00AM fox hunt.
Swine
Swine
Posted: Mon Jan 07, 2008 05:46 PM
About the only way I've ever been able to get the damn thing on is to drop it really hot water first to loosen things up. Not the cap, just the rubber sock.
Posted: Mon Jan 07, 2008 06:25 PM
I dont use them cuz they are a pain in the behind. Plus if you ever have to get to the inside you have to pretty much destroy it to get it off. I just carry a can of WD-40 in the car. If you get the dizzy wet just pop the cap and spray the inside of it and the dizzy with WD-40. The WD in WD40 stands for Water Displacement, and its also non conductive so it wont cause a mis fire or cross fire.
Posted: Tue Jan 08, 2008 05:27 AM
I use a bead of silcone rubber on the base of the cap on my car. Never had a problem with it during the rain.
