Visitors: 98
Total: 98
27: My Account
49: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- lift
lift
cperry2704
cperry2704
Post Post subject: lift
Posted: Sun Jan 06, 2008 07:08 AM
what is the best way to get a few inches of lift on a ball joint baja? cut n' turn? lift spindles? weld in adjusters?
any thoughts? or experience? and how is the ride effected?
Jimmyjack
Jimmyjack
Post Post subject: Re: lift
Posted: Sun Jan 06, 2008 05:07 PM
I just did a cut and turn. Best part? It's free..... but a pain. And it's a s stiff as a board.
Posted: Sun Jan 06, 2008 05:32 PM
how do you do a cut and turn?
Jimmyjack
Jimmyjack
Posted: Sun Jan 06, 2008 10:49 PM
In a nutshell: You use a 3 or 4 wheel pipe cutter (rented it for $8) and cut the center section of the torsion tubes or beams. I'm not sure hwat they're called. Embarassed You rotate them up a 1/4 or less and weld them shut.
I jacked up the front of the car under the pan and I measured 3" out from the center "dimple" each way and cut there. I made a line across the tube and then measured 1.25 " up (I think) as a reference. Then I rotated the center section to the mark and had my buddy tack it. Repeated it for the bottom. It really helps to clamp a piece of angle iron on the torsion bar to align the cut pieces. They'll resist everything you do to make them straight.
After they were tacked together I stitch welded the cuts. Let them cool and finished the cuts, ground and painted.
I didn't go quite 1/4 turn cos it was getting pretty tight so I backed off a little bit.
You need a big pipe wrench and a cheater bar.
Swine
Swine
Posted: Mon Jan 07, 2008 12:24 AM
How soon are you looking to do this? I'm going to be replacing my front end that has less than a 1000 miles (mostly street) on it.
Ball Joint lifted about 3 - 4 inches with adjusters.
cperry2704
cperry2704
Posted: Mon Jan 07, 2008 03:18 AM
well i want to do this soon, i am just wondering about the ride quality, between cuting and turning, a spindle lift, or weld in adjusters...or is it pretty much all the same ride? STIFF!
Posted: Mon Jan 07, 2008 04:01 AM
If you cut and weld or wild in adjusters do one tube at a time.
The raised spindles should keep the ride pretty close to stock but cost alot more.
Swine
Swine
Posted: Mon Jan 07, 2008 02:40 PM
The ride is actually pretty good, I'm running some inexpensive coilover shocks I got from Chirco and they also built the front end.
cperry2704
cperry2704
Posted: Mon Jan 07, 2008 11:06 PM
so cutting and turning, with some decent shocks...the ride wont be too bad?
Jimmyjack
Jimmyjack
Posted: Tue Jan 08, 2008 12:54 AM
Well it's pretty freekin' stiff. And it's more responsive when I turn the wheels. It used to just slide and drift. Also the 1st time I tried to launch my rail it nosedived into the dirt. Now the front doesn't come down so soon, but it's still stiff. Even without shocks it beats me up.
Sample
Sample
Posted: Tue Jan 08, 2008 01:00 AM
So it is really stiff then? My '66 front is cut and turned (not by me). I have only driven it around the block at 15mph max, so I didn't really notice the ride yet. It does have those cheap coilover shocks though.
Jimmyjack
Jimmyjack
Posted: Tue Jan 08, 2008 04:00 AM
You Sample from Wheeling Az? If so I'm the same JimmyJack. I sold my blazer tho....
I weigh 240 lbs and I jump up and down on the front end and it barely moves. I aired my tires down to compensate.
Sample
Sample
Posted: Tue Jan 08, 2008 04:11 AM
I am the same person. I too no longer have a blazer, good to see you.
cperry2704
cperry2704
Posted: Tue Jan 08, 2008 05:14 AM
so when cutting and turning, will i need any new parts to make the front end work? or should it be ok with all the stock parts?
Posted: Tue Jan 08, 2008 05:19 AM
Possibly longer shocks.
25 Kreed 26213 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
Front End question
12 ButchW 7239 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2357 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 1 elryano 2037 Re: body lift
 Thu Apr 12, 2012 02:21 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super Beetle lift kit 5 ghettodish 7988 Super Beetle lift kit
 Sun Mar 27, 2011 12:18 AM
ghettodish View latest post
