Visitors: 115
Total: 115
09: My Account
40: Event Calendar
45: Event Calendar
48: Event Calendar
67: My Account
73: Pictures
77: Event Calendar
94: Home
99: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- I need some advice
I need some advice
The following users give thanks for this topic Anonymous - Tue Apr 14, 2009 02:25 AM
Swine
Swine
Post Post subject: I need some advice
Posted: Wed Jan 02, 2008 06:34 PM
I’ve been given the green light to step up my Baja to the next level. I’d like to take it somewhere around prerunner level and I’ve got a budget of around 10 thousand. This car is a daily driver and if it’s down for a week or two no big deal there is an SUV in the mix but my goal is to keep it a daily driver.
What I’ve got now is a solid 68 pan and pretty much everything is stock. I’d like to start with the front end. Right now I have a raised BJ front end from Chirco, nice but it's still stock. I’d like to go disc with a different raised beam setup with real shocks. Cutting, welding, body mods are not an issue.
What is on your front end and what would you have done differently?
Post Post subject: Re: I need some advice
Posted: Wed Jan 02, 2008 08:36 PM
I good front end would be a 6" wider or more link pin with 4 over arms, coil overs (FOA has good deals) a saco rack, combo spindles and disc brakes. I can build you any length beam you want, with or without shock towers, chirco has a good deal on the tweed arms, and the saco rack.
Swine
Swine
Posted: Wed Jan 02, 2008 09:01 PM
Daryll,
I'm guessing that if I go to a link pin beam I'll need to change out the frame head also? Also, the saco rack... how do they handle on the pavement? I thought I saw something that they are a little spooky on the freeway?
Thanks,
Tom
Posted: Wed Jan 02, 2008 09:13 PM
Well if I can ever get the machine shop to finish my spindle carriers I can build you a conversion beam that will bolt to the balljoint frame head. The saco rack has the provision so you can put a steering dampner on it and should work fine on the street that way.
Swine
Swine
Posted: Wed Jan 02, 2008 09:37 PM
That sounds much better than swapping out the frame head! LMK when your ready and we can talk about the specs.
Posted: Wed Jan 02, 2008 10:47 PM
Will do!
nukeworker
nukeworker
Posted: Thu Jan 03, 2008 05:14 AM
BugZyla, are you saying that you can make a linkpin front end that will bolt up to a ball joint frame head? I thought that couldn't be done. Sorry but I'm a noob. If you can do that, I would be very interested too.
38 NoKnowledgeCollegKid 19933 Thinking about a Baja ...
 Wed Apr 01, 2015 12:01 PM
No new posts VW Volkswagen & Baja Bug General Discussion Build advice 11 RPexpat 7605 Build advice
 Fri Sep 30, 2011 04:20 AM
No new posts VW Volkswagen & Baja Bug General Discussion Build advice ...
17 CatJockey 14997 Re: Build advice ...
 Mon Mar 28, 2011 12:55 AM
CatJockey View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Buying advice
What to expect when buying
12 Brib 6514 Buying advice
 Sat Jan 15, 2011 08:07 PM
Brib View latest post
No new posts Projects and Builds building my first baja.....i could use some advice
74 vindeta 46244 Re: building my first ...
 Fri Jul 09, 2010 12:31 AM
Viatus View latest post
