Visitors: 150
Total: 150
19: My Account
80: Event Calendar
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Booo, gas tank
Booo, gas tank
Sample
Sample
Post Post subject: Booo, gas tank
Posted: Wed Jan 02, 2008 07:37 PM
So I finally thought I was ready to drive my baja around the block for the first time.
Well, it made it.
But it died about 10 times.
Looks like the inside of the stock gas tank started to fall apart as I drove. It clogged the fuel lines and filters, making the engine die.
Is there a cheap rememdy for this? If not, I will buy the cheap 16 gallon gas tank from Chirco for $60.
1966 Baja.
Swine
Swine
Post Post subject: Re: Booo, gas tank
Posted: Wed Jan 02, 2008 07:46 PM
Is it rust or dirt? If it's rust, bite the bullet and get a new tank it will be cheaper and much less of your time.
Sample
Sample
Posted: Wed Jan 02, 2008 07:49 PM
It is rust.
Sample
Sample
Posted: Wed Jan 02, 2008 08:17 PM
What cap fits this tank?
www.chircoestore.com/c...ts_id=4154
Swine
Swine
Posted: Wed Jan 02, 2008 08:22 PM
Once a tank rusts you have two options, replace it or treat it. There are as many recipes for treatments as there are for chocolate cake. The only tank treatment I've ever seen work in the long run is costly and very time consuming. For $60 bucks it's not worth messing around. Make sure you flush your fuel line when you replace the tank.
Sample
Sample
Posted: Wed Jan 02, 2008 08:25 PM
All rubber lines and filter will be replaced. I plan on shooting carb cleaner and compressed air down the hard line in the car.
Swine
Swine
Posted: Wed Jan 02, 2008 08:27 PM
I'd call to double-check but my guess would be this one.
www.chircoestore.com/c...ts_id=1292
Posted: Thu Jan 03, 2008 12:16 AM
Probably the "wrong" one you were just trying to give away... Laughing
Swine
Swine
Posted: Thu Jan 03, 2008 12:38 AM
Oh man I didn't even see the cap # listed in the description of the tank. DOH! Embarassed
Sample
Sample
Posted: Thu Jan 03, 2008 12:44 AM
Good thing I still have it. Especially since it lists which cap to purchase with that tank.
Very Happy
How is the car coming along?
nukeworker
nukeworker
Posted: Thu Jan 03, 2008 05:05 AM
I vote tank replacement. That's what I did. More peace of mind.
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1892 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Help Needed --> Gas Tank Safety!! 2 jk97 2449 Help Needed --> Gas Ta...
 Wed Jul 13, 2011 06:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion stupid leaking gas tank gaskets... 3 Brettucks 3177 stupid leaking gas tan...
 Fri Aug 07, 2009 10:38 PM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Thinking about getting a Long Range 16 Gallon Fuel Tank 10 siacs 4190 Re: Thinking about get...
 Sat Oct 18, 2008 03:43 AM
siacs View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja gas tank behind back seat 13 flyboy942003 11513 Re: Baja gas tank behi...
 Wed Jul 09, 2008 05:06 AM
