Latest: hulkbaja
Overall: 3594
Visitors: 79
Total: 79
01: Home
07: Event Calendar
26: My Account
63: Event Calendar
71: Event Calendar
72: My Account
74: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cost question
cost question
prico
prico
Post Post subject: cost question
Posted: Tue Jan 01, 2008 03:06 AM
what is the average cost for building a baja? they look awesome, and id like to build one. im only 16, so id like to know about how much to save. thanks
Post Post subject: Re: cost question
Posted: Tue Jan 01, 2008 04:16 AM
There are so many factors that make that a hard question to answer. It realy depends on what type of Baja you are talking about, what you start with and how much you can do on your own.
Quick answer, for a normal mostly street drivin-mostly stock $2000-$3000. For a pretty good prerunner $5000-10,000. For a full blown race car $50,000-$70,000.
Posted: Tue Jan 01, 2008 06:26 PM
i agree with mykyl, for a starter baja somewhere around 2500 to 3500 bucks (running). have you looked around your area yet ?
prico
prico
Posted: Tue Jan 01, 2008 06:38 PM
not really. if it helps, it would probably be my everyday driver as well.
Posted: Tue Jan 01, 2008 07:52 PM
i got my baja [ full 7 piece baja kit] for 500 bucks w/ everthing, it kinda ran but needed an engine rebuild
Kev_n_AZ
Kev_n_AZ
Posted: Tue Jan 01, 2008 08:26 PM
no matter how much you decide to spend. make sure to have a repair fund sittin around.
for those "just in case" times .
George Washington
prico
prico
Posted: Fri Jan 04, 2008 04:37 AM
so what would be the best way to start one? what year bug is best, or easiest to convert?
Posted: Fri Jan 04, 2008 04:42 AM
1966-1969 NO SUPER BEETLES!!!!!! but what do i know im only 14:)
Posted: Fri Jan 04, 2008 05:40 AM
Buy the best one that you can afford, then upgrade as nessasary. It's always cheeper to finnish someone else's project then to start your own.
Posted: Fri Jan 04, 2008 06:27 AM
Any year will work, btu no super beetles. all bugs up to 65 had the link pin front end (most desirable front end) and 66 - 68 had ball joint front swing axle rear (least desireable suspension front and rear) 69 & up are IRS rear and balljoint front (IRS is the most desirable rear suspension). So you have a choice. Just buy whatever you find, or get a 65 and earlier and convert the rear to IRS, or get a 69 & up and convert the front to link pin.
Posted: Fri Jan 04, 2008 10:36 PM
that dude was wrong! some guy told me 66-69 were best for baja!
VIN70
VIN70
Posted: Sat Jan 05, 2008 03:08 AM
thats the truth right there..and youll never get the money out of it that you put in it. although there is a certain enjoyment building the whole car..
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 8387 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2905 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5745 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3726 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4643 super baja question
 Thu Aug 29, 2013 11:07 PM
