Visitors: 99
Total: 99
03: Event Calendar
14: Home
15: Home
32: Event Calendar
54: My Account
70: My Account
73: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Spring plate tool
Spring plate tool
Post Post subject: Spring plate tool
Posted: Mon Dec 31, 2007 03:13 AM
Trying to change out my torsion setup. Didn't someone on here have a spring plate "tool"? I've been messing around all afternoon trying to get them unsprung. Problem is there's enough torsion on them that a jack lifts the whole car (no motor). I was even hanging off of a bar I had sticking out about 3' off the back end- still wasn't enough weight to unload one so I could pry it out. I'm trying to install my 28mm SAW short torsion setup. I THINK the stuff that's in it is stock- they're long anyway.
If someone in the EV has one, I'd love to pick it up tomorrow if I could borrow it...
Anyone? Laughing
SuburbanLegend
SuburbanLegend
Post Post subject: Re: Spring plate tool
Posted: Mon Dec 31, 2007 03:55 AM
I would not even try this without the "tool", it's just too dangerous and not worth the time. I got mine from Chirco's
www.chircoestore.com/c...ts_id=2362
and it's been well worth the money. Maybe Karl's has one..? The tool mounts on top of a bolt in the rear body mount hole and hooks under the outer spring plate (on my IRS).
I'm currently in the middle of my project or I'd let you use it (also living on the West side.) There is an unbelievable amount of force required to even use the tool, so be careful! Use a medium size screwdriver wedged under the spring plate and the lowest hole behind it in the rear susp submember. Once the screwdriver is in, lower the plate with the tool slowly and work the plate down and out with a BFH, small pry bar, etc.
Posted: Mon Dec 31, 2007 04:32 AM
Tony, if you can't get a tool I use a floor jack under the spring plate put a chain under the floor jack and up thru the upper shock bolt hole. The chain will keep the body from lifting and the floor jack will collapse the spring. Jack the spring up put a big screw driver behind the plate and slowly release the jack and hit the spring plate with a rubber hammer and it should come off. If it does not, try a couple of more times.
Posted: Mon Dec 31, 2007 04:38 AM
I used a ratchet strap! Yes I am suprised that I still have all of my fingers!!
Posted: Mon Dec 31, 2007 04:54 AM
bajawarrior's idea works like a charm, that is how I do it too.
Posted: Mon Dec 31, 2007 05:01 AM
I will third bajawarriors way, I have always done it like that.
Posted: Mon Dec 31, 2007 08:20 PM
ditto...... Wink
Posted: Mon Dec 31, 2007 09:43 PM
I have the tool if you want to borrow it. I will only be at work until 4 today though. You still have my #?
Posted: Tue Jan 01, 2008 07:12 PM
PM sent to DONT- I no longer can locate his number. If anyone wants to PM me his cell, or let him know I sent him a PM, I'd appreciate it. Would really like to see if he's around today to lend me that tool... Cool
Posted: Tue Jan 08, 2008 01:17 AM
Sorry, I was in Flagstaff having snow ball fights w/my kids. I am back if you still need it. 480.813.5526 wk.
No new posts VW Volkswagen & Baja Bug General Discussion can we clarify the ohv/mc/regular plate/park pass stuff? 7 Brettucks 20173 Re: can we clarify the...
 Wed Feb 16, 2011 03:11 AM
Rickman View latest post
2180 Baja bug with 091 trans.
11 51BUG50 4238 Clutch and pressure pl...
 Fri Mar 10, 2017 07:22 PM
No new posts Events and Get Togethers World Wide Contemplating a Spring Playday 13 Dirtjunkie 4918 Contemplating a Spring...
 Wed Jan 11, 2017 02:36 PM
No new posts Projects and Builds Tool
Plz help
2 Zack149 1923 Re: Tool
 Sat Jul 11, 2015 05:36 AM
No new posts VW Volkswagen & Baja Bug General Discussion Spring Plates 3 Darn_Near 2880 Re: Spring Plates
 Sun Mar 03, 2013 09:12 PM
