Latest: thelataviayoung
Overall: 3584
Visitors: 124
Total: 124
03: My Account
16: Contact Admin
119: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What to use for sealing?
zx10r203
zx10r203
Post Post subject: What to use for sealing?
Posted: Fri Dec 28, 2007 05:09 PM
I got the body off the bug so I can change the floor pans since the old ones look like they can out of the Flintstones car. I was thinking of using the Herculiner to paint the entire floor, kick panels, trunk area, under hood, under the fenders and body... basically anything that can rust or that needs to be protected. But I will be probably be putting in some type of interior or carpet.
Does anyone have any experience with the Herculiner? If so what did you think, how does it hold up? or any other suggestions on what to use?
This is the stuff: JCW Herculiner
Post Post subject: Re: What to use for sealing?
Posted: Fri Dec 28, 2007 06:53 PM
We use herculiner exlusively. It has good coverage, and is very durable. We have the sprayer and do it that way, but you can also roll it on. It will fade to gray after a few years in the sun, but if your just doing the pan you wont have nay problems there. We have done several pans this way.
First we replace the pan halves and do any mods or welding that needs to be done, then we sent the pan out to be blasted and then the herculiner goes on the bare blasted metal.
Here is one of the cars we used it on. We even sprayed the whole inside of the car because the owner didnt want to put upholstery in it..
www.azbaja.com/Forums/...html#14527
It will take 4 quarts to spray a pan top and bottom, not sure how much if you roll it on.
zx10r203
zx10r203
Posted: Fri Dec 28, 2007 07:15 PM
How many coats?
Posted: Fri Dec 28, 2007 07:44 PM
Remember he is spaying his. I dont think he's doing more than one coat (itcomes out pretty thick) I rolled the bottom of my one piece (rolling doesn't go as far. It used all the whole can to do it.
zx10r203
zx10r203
Posted: Fri Dec 28, 2007 08:47 PM
Well I will be driving mine on the dunes so I will be covering as much as possible with it. I guess I will using about 2 gallons of it.
Posted: Fri Dec 28, 2007 09:08 PM
2 coats, the first coat kinda thin, the second a little thicker.
