Visitors: 132
Total: 132
03: Event Calendar
07: Event Calendar
15: Home
35: Home
36: Home
73: Event Calendar
74: Event Calendar
107: Home
111: Event Calendar
119: Event Calendar
121: Home
124: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- oy... throttle cable!
shpuz
shpuz
Post Post subject: oy... throttle cable!
Posted: Wed Dec 26, 2007 08:24 PM
my throttle cable broke today. is it possable for it to just come unhooked from the gas peddle or something? if so, how the HELL do i get to it?
thanks guys.
caversmoon
caversmoon
Post Post subject: Re: oy... throttle cable!
Posted: Wed Dec 26, 2007 09:15 PM
Unhookit from the carburator and pull the piece threw. Then move the driver seat back so that you can get to the gasss peddle. The cable just hook into the peddle and pull the cable out. get the new cable. The new cable will have one end with what looks like a treched out z and the other end has just a stait metal cap. The strat end is feed threw theplace where you took it out from the gas peddle. it will go in for a while then stop. This is because it has run into the tupe that goes threw the fan housing. You will have to reach behind the shroud and finish feeding the cable threw. Before reataching it to the carberator thred the end on to the gas peddle. This process should only take you about five minutes top.
shpuz
shpuz
Posted: Fri Dec 28, 2007 12:01 AM
ok.. so where is the cable at? how/where does it hook up to the gas peddle? i have looked everywhere for it and cant seem to find it.
Quote::
Swine
Swine
Posted: Fri Dec 28, 2007 12:23 AM
The cable runs along the inside of the center tube. The cable exits just forward of where your ankle is when your foot is on the gas pedal. There is a chance the cable broke at the pedal and it would be tough to find if you didn;t know what your were looking for. Look for a short tube, this is where the cable runs. If you still have a stock pedal pull it back a bit and you will see a small roller set-up underneath. There is a small hole in the arm where the "Z" bend on the cable would feed in. If you don't see the cable at this point then the "Z" bend has broken off and is laying on the floor someplace. (If you have a roller pedal it's the same, there will be a hole in the arm)
shpuz
shpuz
Posted: Fri Dec 28, 2007 02:23 AM
yep. got it. thanks alot man. part of the "z" snapped off but theres enough "z" left on there i might be able to bend it back to a hook, that way i dont have to replace the whole thing.
thanks alot guys.
Kev_n_AZ
Kev_n_AZ
Posted: Fri Dec 28, 2007 02:50 AM
if the head broke once, then it will depart from your throttle peddle again very soon.
a new cable runs a few bucks. go buy one and keep it in your vw as a spare..kind of like a ride a long Very Happy
is your vw a baja or stock ride?
George Washington
Swine
Swine
Posted: Fri Dec 28, 2007 02:55 AM
Replace it!
shpuz
shpuz
Posted: Fri Dec 28, 2007 03:00 AM
its a baja. either way, i have to do something with it so i can drive it. i have to order from chirco cause the local shop dosnt have any. and im guessing its going to take a while to get here through chirco.
Kev_n_AZ
Kev_n_AZ
Posted: Fri Dec 28, 2007 03:14 AM
if you order by tomorow, friday, maybe a week at most...
it isnt bulky, maybe priotiy USPS mail for faster delivery .
ok shpuz, since you have abaja, the trottle cable change is decently easy.
in the day light (make sure the car is outside), look at the motor.
on the left side behind the carb should be a small hole with or without a tube stickin out.
this should have the trottle cable inside and then exiting to the carb linkage.
now you will have to crawl under the edge of the baja adjacent to the drivers side rear wheel.
you should see the throttle cable coming from the back firewall by the rear seat and going into the doghouse .
the other cable is the clutch cable . it has a wing nut (ok should have) on the end where it attaches to the trans.
to replace the throttle cable...
remove it from the pedal up front. pull the cable firmly but not too hard in the direction of the front fire wall.
keep doing this till it has completely retracted from the guide tube. the cable will need to be coiled or routed out the drivers door for comfort reasons Very Happy
the new cable is then fed back into the the guide tube from the same point where you removed the old cable.
push the cable almost 100% in.
now, you can either guide it through the dog house at the motor, or hook it to the peddle.
both have to be done, some do it their way Wink
once you are fed through the dog house and to the carb, you need to take the slack out. make sure the cable is now hooked to the peddle.
feed the cable into the linkage on the carb where the old one was connected.
give it a tug to take up the slack.
hold fast with 1 hand (whith slight tension) and snug down the cable clamp (bolt, etc) on the linkage. once the cable is taught and the bolt is 1 finger snug, tighten it more with a wrench and 2 hands.
your new cable should now be in place an ready for use.
if you have any questions ask away.
got camera?
take some pics of the areas I mentioned and post em. we can then guide you through those as a reference. Very Happy
George Washington
Posted: Fri Dec 28, 2007 03:54 AM
I got a cable from Checker/Shuks?/kragan?
It cost me $10 Shocked but I was able to drive the car home that night. Rolling Eyes
Posted: Fri Dec 28, 2007 04:09 AM
You can buy heavy duty cables too, they dont snap as easy.
www.chircoestore.com/c...od8o8975e0
shpuz
shpuz
Posted: Fri Dec 28, 2007 06:17 AM
yeah i just bought a heavy duty cable off of the samba. cost me a total of $9 +shipping.
vwbill
vwbill
Posted: Fri Dec 28, 2007 01:40 PM
Isn't that heay duty cable the same as a clutch cable? Have you actually seen a gas pedal snap one of those? That seems bullit poof to me.
William
Posted: Fri Dec 28, 2007 02:47 PM
They are a little smaller than a clutch cable, just about the same size as the barrel on the end that connects to the carb. I have never seen a HD cable snap.
No new posts VW Volkswagen & Baja Bug General Discussion sticking accelerator cable 11 65bajabug 4625 Re: sticking accelerat...
 Wed Mar 13, 2013 12:29 AM
nshoe18 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Throttle cable shenanigans... 4 fast_1 2533 Re: Throttle cable she...
 Wed Apr 22, 2009 02:23 AM
fast_1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion throttle cable.
20 shpuz 4342 Re: throttle cable.
 Tue Jan 22, 2008 12:11 PM
kcnaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion speedometer cable instal 6 todd 2988 Re: speedometer cable ...
 Sun Aug 12, 2007 05:46 PM
todd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Throttle Cable 1 zfriek42083 2122 Re: Throttle Cable
 Tue Jun 05, 2007 06:29 AM
