Latest: ecthemc
Overall: 3567
Visitors: 88
Total: 88
40: Pictures
82: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- baja engine change idea
Kev_n_AZ
Kev_n_AZ
Post Post subject: baja engine change idea
Posted: Mon Dec 24, 2007 11:27 AM
would it be feasable to install a cummins turbo deisel 5.9L inline 6 engine in the back of a baja?
it turn the proper direction.
I am worried about the low torque twisting the pan all to heck.
any ideas???
George Washington
vwbill
vwbill
Post Post subject: Re: baja engine change idea
Posted: Mon Dec 24, 2007 02:41 PM
The stock VW is 250lbs. The 4 cyl ford some guys here use are 400lbs. Even LS1 only weighs in about 600lbs. The 6BT5.9 about 1500lbs. You would need to do a lot of bracing and it would easily lift the front end. If you want diesel look into the 4BT3.9 or I have seen pictures of VW TDI in bugs.
William
Posted: Mon Dec 24, 2007 02:50 PM
First switch the 59 baja over to IRS, then add 12x12 arms to keep it from tipping over backwards. Shocked
Kev_n_AZ
Kev_n_AZ
Posted: Mon Dec 24, 2007 04:40 PM
59?
I dont not know what you are talking about.. Shocked
Very Happy
Laughing
George Washington
tigerextra
tigerextra
Posted: Mon Dec 24, 2007 07:19 PM
dang 12x12 would be hilarious!!!!!!! like spider running down the street! talk about bracing the 12x12's... hummmm.. we should try this, they would need to be arced like a bridge or 53' long haul semi flatbed trailer... bowed to accept the length.. hmm daryll i think youre onto something here...
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
Posted: Mon Dec 24, 2007 07:57 PM
any ideas???
Shocked Shocked Shocked
Posted: Tue Dec 25, 2007 12:01 AM
Hi Kevin.
Posted: Thu Dec 27, 2007 12:52 AM
Wow Kevin, is it April fools already?
Kev_n_AZ
Kev_n_AZ
Posted: Fri Dec 28, 2007 02:48 AM
youre supposed to let the "new" guys answer this one ..sheesh Very Happy
George Washington
Posted: Fri Dec 28, 2007 05:13 AM
SUP KEVEN!!
Posted: Fri Dec 28, 2007 05:43 AM
To quote Cheech Marin. "Waaasapenin"
4 Admin_AzBaja 5060 Baja Bugs on Wiki need...
1567 mufasavnvmc 838710 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 205817 Re: Baja sightings
Off-road event
1 wideopenmotorsports 125 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 203 Re: Engine Work
 Mon Jan 08, 2018 12:59 AM
