Visitors: 98
Total: 98
05: My Account
32: Event Calendar
63: Event Calendar
70: My Account
72: Event Calendar
82: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- simple single or 2 barrel carb
nube_w_1970baja
nube_w_1970baja
Post Post subject: simple single or 2 barrel carb
Posted: Sun Dec 23, 2007 09:26 PM
i've been thinking about getting a different carb.
the Weber i have now is almost impossible to adjust. the air/fuel mixture is between the back of the carb and almost up against the doghouse. vacumm ports on both sides (i don't need either of them,) and the top plate to hold the air filter covers any access to the mixture screw. it's hard enough to see it clearly, let alone to get maybe a bent needle nose on it and impossible to get a screw-driver on it.
so what i'm looking for is a single or dual barrel carb, i don't care who makes it, just be easy to tune.
the intake i think is by SCAT w/ the plenum.
i have a 1641 with d/p heads, low end power would be nice, but reliablity and power all through the range would be nice.
anybody have one laying around or suggestions?
good times,
jeff
Post Post subject: Re: simple single or 2 barrel carb
Posted: Mon Dec 24, 2007 01:41 AM
What you have is a Webber progressive carb. They are petty good for street but not so hot for off road. Ebay or Craig's list it and get what you want. There are a lot of opinions on what the best carb is and it can get really confusiong when you're starting off.
My opinion- If you don't know much or don't have a bunch of money to spend, get a stock carb and get the engine tuned up right before you throw a bunch of money at it. Hage out with VW people and ask a lot of questions. When you feel like you know what you want and have the money, upgrade.
fatalifeaten
fatalifeaten
Posted: Mon Dec 24, 2007 03:37 AM
What Mykul said.
--Harlan Ellison
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5777 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts Projects and Builds Brandwood Single seat project
New project side I just picked up
9 hanksgt 7146 Brandwood Single seat ...
 Thu Aug 02, 2012 07:43 AM
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 2102 Re: Carb Intake Covers
 Wed Jan 11, 2012 12:46 AM
Gunpilot View latest post
No new posts Projects and Builds carb troubles
1968 carb troubles
11 vwbajabug1 4686 carb troubles
 Mon Nov 15, 2010 03:12 AM
vwbajabug1 View latest post
No new posts Projects and Builds wanting 34 pict-3 carb
i need a carb
0 vwbajabug1 1674 wanting 34 pict-3 carb
 Tue Nov 09, 2010 01:07 AM
