Visitors: 123
Total: 123
50: Pictures
68: My Account
81: Event Calendar
103: My Account
109: My Account
115: Event Calendar
123: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- turning brakes?
turning brakes?
speedtrash
speedtrash
Post Post subject: turning brakes?
Posted: Wed Jul 05, 2006 07:50 AM
could someone explain turning brakes to me.
i thought they were just parking brakes but at a closer glance they seem more complicated than that.
carpe diem
"sieze the carpe"
Post Post subject: Re: turning brakes?
Posted: Thu Jul 06, 2006 04:21 AM
Yes, one brake will hit each rear wheel. you can use them like a fake posi. If a wheel comes loose or spins you can tap the speed down with the brake to free the car. you also use them to help you turn in the loose stuff. You hit the brake on the inside wheel of your turn and stay on the gas and you will get a real nice turn out of your car. Most new cars have this added to it, but the computer will do the work. You run the brakes your self. Last you can do some real cool spins, just lock one of the brakes up and turn into it and the car will flip 180' in a turn and it's that fast. Brakes is realy the wrong term for them, they should be called turning aids.
speedtrash
speedtrash
Posted: Thu Jul 06, 2006 08:30 AM
now if i buy the dual handle turning brakes do i replace my parking brake with these or is this another brake setup on it's own?
carpe diem
"sieze the carpe"
Posted: Thu Jul 06, 2006 09:11 AM
The parking brake is a cable and if you can try and keep it as it's a good thing to have. I do not have a parking brake Sad my car is a wheel disc with no option for the parking break. The turning breaks ket spliced into your normal barke lines.
Posted: Thu Jul 06, 2006 02:11 PM
my understanding is that they used to sell cable turning brake handles. those are long forgotten though. you have to cut your break line goin to the rear and install the break splitter. perrty much its a "Y" for the break line.
go here:
www.chircoestore.com/c...ds=+brakes
speedtrash
speedtrash
Posted: Wed Jul 12, 2006 06:16 AM
i thought a single handle turning brake setup would control both brakes with a pull in one direction, but i just noticed that the single handles have little hydraulics(please tell me the name of these things as i'm sure they're not called hydraulics but you guys know what i'm talking about) on both sides of the pivot point.
so does a single handle turning brake control the tires simultaneoulsy or individually?
what do all you desert racers prefer? single or dual?
carpe diem
"sieze the carpe"
Posted: Wed Jul 12, 2006 10:46 AM
The single is forward for one brake and back for the other brake. some racers like this set up as you do not have to remove your hand from one brake to the other brake when racing.
term would be master cylender.
speedtrash
speedtrash
Posted: Thu Jul 13, 2006 08:22 AM
thanks for the clarification
carpe diem
"sieze the carpe"
69bapbaja
69bapbaja
Posted: Thu Jul 13, 2006 04:52 PM
to answer the questions about useing the hand brake as a turning break. Yes you can there is a kit in empi or bugpack. I can't order the bug pack but i can order the empi one. If you look at the safty brake cables there is one per side. Ie the kit comes with two handles, which activates the brake that you desire. So instead of the hydrolic pressureyou have to use brut stregth. the hydrolic ones I would only suggest in a sandrail. Because driveing in deep sand is like driving a boat the front wheels will act as rutters, and back wheels do the turning of the car.
personaly. if your car is fully (cage and harneses)set up then go with it, if not leave them alone. WHY you ask, with the turning break people tend to stop and think about what the back end is doing in the sand. alot of people will try and take a corner fast and hit the leading wheel break, which makes the inner wheel have the traction ie pushing the backend around like driffting. the problem is that the sand or loose dirt or rocks gathers on the leading wheel. Now if there is enough momentum and it doesn't take much, it will roll over or simply enough roll the wheel off the rim. two things that will trash your car and your self. So personaly learn how to feel the car with your ass, if you feel the car wnatin to go a certain way you can correct it or power through it, because if the wheels have the power it will not gather the dirt but to push it under the wheel.
anyway thats my .15 on the subject.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
speedtrash
speedtrash
Posted: Sat Jul 15, 2006 03:52 AM
well i guess i need to start on that cage
carpe diem
"sieze the carpe"
SandRacer
SandRacer
Posted: Mon Aug 14, 2006 07:49 PM
It was Bugpack that made the old mechanical steering brakes. I had them on my first Baja and a set came on my Manx. They worked out quite well for the Baja for slow speed trail running. They came in real handy when trying to climb out of a wash (off camber) or while negotiating rugged terrain.
I have actually been looking for another set for my new Baja but it looks like no one is selling them any more. They suit my current style of off-roading (mostly exploring) and are a real easy install.
1976 Baja Bug
speedtrash
speedtrash
Posted: Tue Aug 15, 2006 11:05 AM
do they put a lot of wear and tear on your brakes?
carpe diem
"sieze the carpe"
SandRacer
SandRacer
Posted: Tue Aug 15, 2006 05:35 PM
I suppose it would depend on how often you use them. In my case, I used them only rarely when I needed to direct traction to the opposite tire. It's kind of like insurance; you may not need it all the time but when you do, you're sure glad it's there.
Since they operate using the emergency brake cable they only activate one brake shoe where as the current "hydraulic" type cutting brakes activate both shoes. If you are intending to use them a lot at the dunes, especially in a rail, I would definitely go with the hydraulic type.
For slower speed, desert or mountain use - crawling through the rough stuff, the mechanical brakes are a cheap alternative. They are also a very easy install and still retain the use of the stock emergency brake.
Now if only a set will show up on eBay. Wink
1976 Baja Bug
69bapbaja
69bapbaja
Posted: Thu Aug 17, 2006 07:17 AM
you can make them. flat steal and some elbo grease.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
SandRacer
SandRacer
Posted: Fri Aug 18, 2006 02:40 AM
I'm keeping that as my last option. No sense reinventing the wheel if I can pick up a set at a reasonable price. If I can't then it's time fab some up.
1976 Baja Bug
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3137 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion baja / turbo / turning breaks,
info needed.
11 Jc26 7445 baja / turbo / turning...
 Tue Jul 19, 2011 04:38 PM
Jc26 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Mechanical Turning Brake 5 glenf 2771 Mechanical Turning Bra...
 Mon Jun 01, 2009 10:35 AM
No new posts VW Volkswagen & Baja Bug General Discussion front brakes on a sandrail 2 Thuff 2173 Re: front brakes on a ...
 Thu Jan 29, 2009 03:11 AM
No new posts VW Volkswagen & Baja Bug General Discussion Emergency Brakes With 3x3 Arms 0 57baja 1869 Emergency Brakes With ...
 Sat Sep 20, 2008 07:48 AM
57baja View latest post
