Latest: George
Overall: 3576
Visitors: 117
Total: 117
15: Event Calendar
40: Home
44: Event Calendar
58: Event Calendar
59: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- oil block off plate ports... in? and out?
nube_w_1970baja
nube_w_1970baja
Post Post subject: oil block off plate ports... in? and out?
Posted: Sun Dec 16, 2007 07:01 PM
the block off plates to direct oil to an external oil cooler/filter sticking out from under the dog-house are stacked on top of each other.
only problem i am running into before i hook anything up is, i don't know which one is for oil going out and oil returning to the engine.
can anyone tell me if the top or bottom, sends or receives oil?
i don't want to fry the motor, blow 5 quarts of oil all over my dads garage, lose project car work area and have to find a cheaper hobby just because of some oil line hook-up...
good times,
jeff
Post Post subject: Re: oil block off plate ports... in? and out?
Posted: Sun Dec 16, 2007 09:21 PM
If you do you had better of spilled two off the shelf! The engine doesn't take that much!
I wish that I could help you on with is in/out but I can't remember.
Posted: Sun Dec 16, 2007 10:53 PM
I believe the the top one on the adapter, ot the closest one to the distributor on the case is the out. You can just crank it over by hand and see which one pumps the oil out.
No new posts VW Volkswagen & Baja Bug General Discussion can we clarify the ohv/mc/regular plate/park pass stuff? 7 Brettucks 18425 Re: can we clarify the...
 Wed Feb 16, 2011 04:11 AM
Rickman View latest post
2180 Baja bug with 091 trans.
11 51BUG50 3289 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
No new posts VW Volkswagen & Baja Bug General Discussion Fabbed new plate mount and light 9 Tcatdrv 3809 Fabbed new plate mount...
 Sun Jul 04, 2010 07:41 PM
Tcatdrv View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What Clutch and Pressure plate? 5 Lucky7-11 2228 Re: What Clutch and Pr...
 Fri Apr 11, 2008 01:03 AM
ridinthedunes View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Which Adjustable Spring plate for a '73 w/ IRS?!?! 4 zx10r203 2307 Re: Which Adjustable S...
 Wed Apr 09, 2008 02:50 AM
DONT View latest post
