Visitors: 99
Total: 99
13: Event Calendar
17: Pictures
41: Event Calendar
55: Event Calendar
61: Event Calendar
73: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- long travel
long travel
mxride83
mxride83
Post Post subject: long travel
Posted: Fri Dec 14, 2007 05:58 AM
i am new to this and am wanting to build a long travel class 5 baja bug. i was wondering what is the best front end set up and rear suspension set ups to get the most travel. i wanted to get the 6 or the 10 in wider front end but i dont know all the parts i need to get and i would like to know what the best possible set up would be and i am going to convert it to link pin.
Post Post subject: Re: long travel
Posted: Fri Dec 14, 2007 02:29 PM
CHECK OUT SOME OF OR OLDER FORUM,S THERE IS ALOT OF STUFF IN THERE COVERING THAT STUFF,,,,AND WELCOME AND GOOD LUCK!
Posted: Fri Dec 14, 2007 03:57 PM
If you go with a VW style front beam you will get at best a medium travel car, which will probably work fine even if you want to race it. If you want a true long travel car, you better plan on using an a-arm front suspension. As far as the rear goes, you can get about 18 inches of travel with 5x5 arms and 14" coil overs. You will need 930 or 934 CVs though.
mxride83
mxride83
Posted: Fri Dec 14, 2007 06:29 PM
well the baja rule book says it has to stay with the same purpose style of the old one so i think im going with a vw front axle beam. but i want to go with the 6,8, or 10 wider beam with taller shock towers but i dont know what all i need to buy to accomidate with the longer beams
Posted: Fri Dec 14, 2007 08:13 PM
Well the best thing to do is get your rear suspension together (with tires & wheels) so you can get a width. Then mock up the front with a stock width beam, and all of your other stuff and make the beam wide enough to have the front the same or up to 1 inch wider that the rear track width.
mxride83
mxride83
Posted: Fri Dec 14, 2007 08:15 PM
so do u think i will have to get a beam fabricated or could i buy a warrior one from chirco
Posted: Fri Dec 14, 2007 09:38 PM
It will be fabricated to get the longest travel. Bugzylla makes them custom. The Warrior beams are for torsions, if you want to go longer travel than c/o is your answer.
Your setup for racing: custom beam to match the rear, 4" longer trailing arms with the lower arm w/shock mount on top, coilover carrier shocks, bypass shocks, through rods and the upper shock mounts built into the cage, king kong combo spindles, rack and pinion with power steering.
Classic class 5 front suspension.
Or if you need cheaper, several other ways.
Posted: Sat Dec 15, 2007 02:11 AM
how much money do you have mxride ?
buying all the best parts is very expensive.....
mxride83
mxride83
Posted: Sat Dec 15, 2007 03:07 AM
well i already have the vehicle and will have about 20,000 but im only wanting to have to spend up to 15,000
tigerextra
tigerextra
Posted: Sat Dec 15, 2007 03:08 AM
speeking of money, ive been short lately Confused ... say anyone wat to donate? i can make it a tax write off.... Very Happy
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
Posted: Sat Dec 15, 2007 03:09 AM
wish i had a budget like that....you should have one sweet ride when you get it done... Wink
tigerextra
tigerextra
Posted: Sat Dec 15, 2007 03:11 AM
if you would like, i can get you one for 10k then you can just "donate" the otehr 10k for my Vdub addiction.... Laughing
all 6 of us agree!!
mxride83
mxride83
Posted: Sat Dec 15, 2007 05:04 AM
no thanks im good.
mxride83
mxride83
Posted: Sat Dec 15, 2007 05:07 AM
no thanks im good.
Posted: Sat Dec 15, 2007 07:52 AM
$15K-$20K is a realistic budget for a 5 car. You can save a few buck on shock if you go with the FOAs. One of the guys there used to work for fox, same basic quality without all of the advertizing money involved so much better price. You can get 4 14" coil overs with springs & hardware for $1677 plus shipping.
No new posts New Members Newbie from "florduh" here. Mid travel build. 9 shawn813 4990 Newbie from "florduh"...
 Thu Apr 18, 2013 11:13 PM
shawn813 View latest post
75 T_Town_Baja 101844 Re: Mid Travel Manx - ...
 Sat Dec 01, 2012 09:19 PM
jmert View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 7412 Wheel travel stock vs....
 Tue Jan 31, 2012 02:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Well that didn't take long 7 DanMach 4987 Well that didn't take ...
 Thu Jan 20, 2011 10:58 PM
No new posts VW Volkswagen & Baja Bug General Discussion Hey Guys......long time just to busy
15 bajawarrior 9023 Re: Hey Guys......long...
 Fri Dec 10, 2010 03:22 AM
kellyj994 View latest post
