Latest: Milkmanbryan
Overall: 3583
Visitors: 108
Total: 108
58: Event Calendar
101: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- is there a stronger balljoint
wtracing
wtracing
Post Post subject: is there a stronger balljoint
Posted: Mon Dec 10, 2007 09:12 PM
is there a stronger balljoint i can use on my baja?
fatalifeaten
fatalifeaten
Post Post subject: Re: is there a stronger balljoint
Posted: Mon Dec 10, 2007 09:32 PM
hahahahahaha!
Sorry, I know it's not really funny, but it is.
--Harlan Ellison
Posted: Mon Dec 10, 2007 10:18 PM
No. They only balljoints available are sthe stock ones, and there is an aftermarket for more travel, but they are weaker than the stock ones. Bottom line go link pin if you want strength.
vwbill
vwbill
Posted: Tue Dec 11, 2007 02:12 AM
I thought the thing used both balljoints pressed in from the top making them stronger, and rare.
William
Posted: Tue Dec 11, 2007 02:21 AM
The thing does have both pressed in from the top, but it doesnt make them any stronger. The reason for them being pressed in from the top is the spindle design and resulting in 3 inches of lift.
Posted: Tue Dec 11, 2007 06:40 PM
Most people who race w/ball joint only use the German ball joints. Here is 1 from Chirco's:
www.chircoestore.com/c...ts_id=1159
r8rfan66
r8rfan66
Posted: Wed Dec 12, 2007 01:13 AM
I have a Thing beam on my baja. Link pin wasn't an option as I would have had to cut the head off my pan. The thing beam has the balljoints pressed in from the top so when you hit the bumps, the ball joints are pushed into thier seats. Limiting the rebound helps prevent them from coming un-seated when the suspension rebounds. The tie rods and tie rod ends are also heavier than the regular b/j beam...
Would be nice to have a linkpin, but when life gives you lemons.....
Wasn't there someone here that was designing a link pin conversion fro b/j pans??
Posted: Wed Dec 12, 2007 01:44 AM
I have the beams done, just waiting on the l/p carriers to be finished. Should be ready after the first of the year.
