Latest: Curtis
Overall: 3613
Visitors: 155
Total: 155
20: Event Calendar
21: Pictures
24: Event Calendar
61: Home
72: Event Calendar
74: Event Calendar
90: Event Calendar
99: Event Calendar
104: Home
107: My Account
114: Event Calendar
119: Event Calendar
152: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- installing engine
installing engine
cperry2704
cperry2704
Post Post subject: installing engine
Posted: Tue Dec 04, 2007 04:52 AM
ok so this will my first time installing an engine...i have a 66 and a 1600 i just had built...how easy is this? any tips? and any steps that will help a first timer!
thanks guys
nukeworker
nukeworker
Post Post subject: Re: installing engine
Posted: Tue Dec 04, 2007 05:17 AM
Real simple, especially with a Baja. Did it all by myself with a floor jack. The hard part is lifting it up onto the jack. I put a small piece of plywood on the jack. Once on, you just jack it up till you can get a bolt started. There's only four. Bolt it up, hook up the wires and you're in business. Good luck.
fatalifeaten
fatalifeaten
Posted: Tue Dec 04, 2007 06:16 AM
I'd STRONGLY suggest getting the muir idiot book. It goes over how to install an engine step by step in simple terms, and it's worth the 20 bucks or 25, whatever it is this week.
--Harlan Ellison
tigerextra
tigerextra
Posted: Tue Dec 04, 2007 08:08 AM
make sure your clutch and throwout are inline and fitted tight. that easy, you can tell when its not (it will be loose Confused ) then be sure to grease your starter teeth a bit and i found a LITTLE grease is helpful on the trannys input shaft. it should just slide in real nice with the a little lube.
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
Staff Officers
Posted: Tue Dec 04, 2007 08:11 AM
do not for get the clutch alighnment tool thing. that is the key!!!! Then find another Bozo to help you out and lift it up and into place. You can have the engin in and out under 10 min and if you have a good wire/plug in set up and no oil lins you can have it up running and driving in 15 min.
tigerextra
tigerextra
Posted: Tue Dec 04, 2007 08:33 AM
i can never remember the name of that tool.... but yes AZ has a good point, (dOh! moment on my part) align your clutch properly and you will have no problems.... the Muir book and/or VW chilton books can show you exactly how Smile good luck!
all 6 of us agree!!
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 05:35 AM
does it matter if the starter is installed before or after the engine?
Posted: Wed Dec 05, 2007 06:20 AM
DOES NOT MATTER, EASYEST TO PUT THE STARTER IN BEFORE THE ENG THOUGH!!
fatalifeaten
fatalifeaten
Posted: Wed Dec 05, 2007 09:46 PM
Another thing that's V.handy to use if you've got it, is an ATV/Motorcycle jack. The motor sitc on it nicely, rather than struggling with a single pivot point like on a conventional platform jack.
--Harlan Ellison
tigerextra
tigerextra
Posted: Wed Dec 05, 2007 11:27 PM
^^ ditto
all 6 of us agree!!
Posted: Thu Dec 06, 2007 10:16 PM
You can get a trans jack top section that mounts on a regular jack which makes it easy also!
Here's one: store.summitracing.com...toview=sku
Or another cheap alternative: www.harborfreight.com/...mber=39178
cperry2704
cperry2704
Posted: Fri Dec 07, 2007 02:22 AM
alright got the engine in and bolted up, but i noticed he engine and trans seem to have play in it( like rotational) i can kind of rotate the whole thing maybe a 1/2 on rotation
Posted: Fri Dec 07, 2007 02:48 AM
what kinda play are you talking about ?
cperry2704
cperry2704
Posted: Fri Dec 07, 2007 02:50 AM
well i called the local vdub shop, they said its most likely the trans mounts...since the engine is secure to the trans...its the trans moving in the pan
Posted: Fri Dec 07, 2007 03:24 AM
Take it back out and stick a solid mout strap kit in there. You'll get a little extra noise but that's not a bad thing in a Baja!!! Twisted Evil
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 2533 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 3715 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 3491 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 3338 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 6571 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
