Visitors: 123
Total: 123
04: Home
11: Event Calendar
32: Links
42: Event Calendar
44: Home
45: Home
54: Event Calendar
65: Event Calendar
81: Event Calendar
83: Garage
102: Links
106: Event Calendar
110: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- leaking axle
leaking axle
cperry2704
cperry2704
Post Post subject: leaking axle
Posted: Sun Dec 02, 2007 07:48 PM
so im working on my 66.....we took the engine out and replaced te rear axle boots and all the seals...but now the passenger side is leaking fluid....help!!!
fatalifeaten
fatalifeaten
Post Post subject: Re: leaking axle
Posted: Mon Dec 03, 2007 07:50 PM
where's it leaking from? You didn't get the boots on tight enough if they're leaking. Turn them so the split faces backwards on the axle (screws running vertically), and make sure the clamps are nice and tight.
If you're leakin form teh drums, then you didn't get the seal kit on correctly or damaged i when you put it in. Tear it out and start over.
Good luck! Smile
--Harlan Ellison
cperry2704
cperry2704
Posted: Mon Dec 03, 2007 10:49 PM
thanks
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 04:38 AM
alright i took that boot off, and it looks like two of the nuts pulled through their hole on the boot right near the clamp that goes around the axle
Posted: Wed Dec 05, 2007 04:49 AM
THEY JUST NEED TO BE SNUGG,,,DONT OVER TIGHTEN!!
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 04:51 AM
does that gap need to be filled with silicone or gasket sealer, along with the bolts?
Posted: Wed Dec 05, 2007 05:03 AM
NO THERE IS A LIP IN THERE MAKE CERTAIN THE LIP IS IN THE GROVE THEN SNUG THE BOLTS TILL THE GAP IS CLOSED, IF THERE IS NO LIP, JUST SNUG BOLTS LIKE I SAID BEFORE , WERE DID YOU GET YOUR BOOT,,ARE THEY THE GOOD KIND?
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 05:08 AM
yeah they are good quality, got them at my local v-dub shop here an san diego
Posted: Wed Dec 05, 2007 05:09 AM
Smile
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 05:20 AM
while im here, what is the easiest way to get some space, so i can slide the boot around the axle?
Posted: Wed Dec 05, 2007 05:23 AM
JACK IT FROM THE SHOCK TOWER!
fatalifeaten
fatalifeaten
Posted: Wed Dec 05, 2007 08:42 PM
what jamesr said. Smile
--Harlan Ellison
16 DerekT 4112 Axle's needed
 Sat Dec 10, 2016 06:17 PM
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 4197 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2845 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion another rear axle question 3 onthefarm 2847 another rear axle ques...
 Sat Aug 04, 2012 05:22 AM
onthefarm View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 61 bug swing axle to 67 bus swing axle help 5 pussiwillow 5041 61 bug swing axle to 6...
 Fri Jan 28, 2011 06:39 AM
Gettinsomeair View latest post
