Visitors: 114
Total: 114
23: Event Calendar
35: Drivers
49: My Account
70: My Account
87: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Lift
Lift
cperry2704
cperry2704
Post Post subject: Lift
Posted: Mon Nov 05, 2007 02:32 AM
i am semi new to the whole baja scene....i have a 66' baja, and would like to get some lift out of the front.
what is the best way to get maybe 2-4 inches?
Post Post subject: Re: Lift
Posted: Mon Nov 05, 2007 02:42 AM
weld in adjusters or buy a beam the already has him in place. and to answer your other question, you'll need longer tie rods as well...
cperry2704
cperry2704
Posted: Sun Dec 02, 2007 08:19 PM
if i were to buy those adjusters, does it come with instructions where to install and weld?
Posted: Mon Dec 03, 2007 01:08 PM
This is a link to a cut a turn, this is an option without adjusters.
cut and turn by Rick
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 04:54 AM
so how does cutting and turning the beam, raise the car? that has me confused
BajaJoe
BajaJoe
Posted: Wed Dec 05, 2007 05:32 AM
it angles your trailing arms down more which push the front end up
Posted: Wed Dec 05, 2007 02:57 PM
the beam is like a crad board roll of TP. if you cut the center out and rotate it a 1/4" or so it will roatate your traling arms down the same amount of degrees, this will lift the car, do not go hog wild on this or you will realy screw stuf up.
cperry2704
cperry2704
Posted: Thu Dec 06, 2007 10:30 PM
what is the most rotaton on the center section you would recomend?
bajatink
bajatink
Posted: Thu Dec 06, 2007 11:30 PM
Most people say 1/4" to give about 3-4" of lift. More than that and stuff gets in a bind and steering gets out of wack
25 Kreed 26230 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
Front End question
12 ButchW 7242 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 2357 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 1 elryano 2037 Re: body lift
 Thu Apr 12, 2012 02:21 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super Beetle lift kit 5 ghettodish 7988 Super Beetle lift kit
 Sun Mar 27, 2011 12:18 AM
ghettodish View latest post
