Latest: Milkmanbryan
Overall: 3583
Visitors: 111
Total: 111
05: Event Calendar
14: Home
47: Home
75: Home
93: Pictures
105: Pictures
111: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Chirco roll cage for Super got a question....
jeepnut7261
jeepnut7261
Post Post subject: Chirco roll cage for Super got a question....
Posted: Fri Nov 30, 2007 12:06 AM
OK, I have a 74 Super, yes I know it's a bear to Baja, but I am going to try anyway.
SO, can I use the 6 point roll cage advertised here from chirco to use as a base to build a tube front? Or do I need something heavier?
I've built stuff for Jeeps, so I can bend pipe and weld (grind too) and I am thinking of just copying a rail front end (sort of) to put an regular beetle front axle on.
So, any suggestions? (besides getting another year)
Flat learning curve............
DOGLESS HIPPIE!!!
oh, wait, I have a dog, uhh, or maybe cat, uhh, goldfish???? I don't think it's one of the kids....
Post Post subject: Re: Chirco roll cage for Super got a question....
Posted: Fri Nov 30, 2007 02:18 AM
probable a type-o...you wrote pipe...you mean tubing correct ?
sorry dont have a answer for your question.
Posted: Fri Nov 30, 2007 02:19 AM
I think it would be a good base. If you do that then you could easily convert the front end.
jeepnut7261
jeepnut7261
Posted: Fri Nov 30, 2007 02:32 AM
Yep, tubing. Embarassed
DOGLESS HIPPIE!!!
Posted: Fri Nov 30, 2007 04:32 AM
You should be able to use the cage. The only problem that you might run into is the front hoop hitting the dash, but it may not. The rear will fit for sure.
jeepnut7261
jeepnut7261
Posted: Fri Nov 30, 2007 04:37 AM
Front hoop? Do you mean the dash bar? Hey, cut and bend, then weld again!!
I am going to take the body off the pan this weekend, so I will have a better idea about reinforcing the pan for attachment too.
DOGLESS HIPPIE!!!
vwbill
vwbill
Posted: Fri Nov 30, 2007 11:57 PM
Some where I read supers bodys differ from standard bug by 1" between front fender and door. From door back they should be the same. Chassis differ at frame head. Not sure how your curved window and padded dash measure up though.
William
Posted: Sat Dec 01, 2007 12:54 AM
71 & 72 supers are the same from the dash back. The 73 & up im not so sure on the cage clearing the dash, but they do take the same doors so it might just clear.
tigerextra
tigerextra
Posted: Mon Dec 03, 2007 12:36 AM
an easier way to fab the front end for the link pin is to cut the McPherson crap off then weld on a link pin frame horn. thats what i did and am planning to have Bugzyla and gang strengthen all that into the cage. just make sure its all square. you can even give yourself another six inches or so in length depending onh your preference. . let me know if you have any questions!
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
jeepnut7261
jeepnut7261
Posted: Mon Dec 03, 2007 12:28 PM
OK, first question...
I have seen where others online have done that, where can I find a link pin pan?
DOGLESS HIPPIE!!!
Posted: Mon Dec 03, 2007 03:29 PM
You can buy just the frame head from Chirco
www.chircoestore.com/c...9rvi7uh6q0
tigerextra
tigerextra
Posted: Mon Dec 03, 2007 06:02 PM
this is a very simple and effective way of transforming your super into an IRS/link pin baja. just MAKE SURE ITS SQUARE! i cant stress that enough... also good welds are a plus. note in the pic that i drilled half inch holes in the frame head BEFORE i mounted it, then "spot welded" the holes to the pan. dont forget to grind and clean all contacting metal for good penetration. i also beefed up all contacting ends with a few thick welds for structure. also it is imperative that you strengthen the beam to the cage, not that this isint already very strong if you do it right, but you can never be too strong! good luck
>ask questions when you are unsure, cut once and measure fifteen times.
all 6 of us agree!!
Posted: Tue Dec 04, 2007 01:46 AM
Good job!!! Cool
tigerextra
tigerextra
Posted: Tue Dec 04, 2007 07:05 AM
Mykul wrote:
Good job!!! Cool
me? thanks mykul. i appreciate man Smile its got a long ways to go... have almost everything (except for suspension ca$h) then its goin together!!!!! two years and counting!
all 6 of us agree!!
25 Kreed 25569 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
18 Dirtjunkie 6195 Official 2016 Hassaymp...
 Tue Nov 08, 2016 02:49 AM
42 wideopenmotorsports 13822 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 03:14 AM
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 7676 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2068 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
