Visitors: 222
Total: 222
02: My Account
11: My Account
16: My Account
23: Event Calendar
35: Home
51: My Account
53: My Account
65: My Account
67: My Account
73: My Account
74: My Account
84: My Account
86: Pictures
90: My Account
93: My Account
96: Home
97: Home
98: Home
99: Home
100: Home
105: My Account
129: Links
134: My Account
137: My Account
138: My Account
141: My Account
166: Baja Forums
170: Baja Forums
182: Baja Forums
183: Event Calendar
190: AMAZON.com
194: Baja Forums
197: AMAZON.com
198: AMAZON.com
202: My Account
204: My Account
205: AMAZON.com
207: AMAZON.com
208: My Account
209: AMAZON.com
210: AMAZON.com
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
216: My Account
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
222: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- leaking axle
leaking axle
cperry2704
cperry2704
Post Post subject: leaking axle
Posted: Sun Dec 02, 2007 08:48 PM
so im working on my 66.....we took the engine out and replaced te rear axle boots and all the seals...but now the passenger side is leaking fluid....help!!!
fatalifeaten
fatalifeaten
Post Post subject: Re: leaking axle
Posted: Mon Dec 03, 2007 08:50 PM
where's it leaking from? You didn't get the boots on tight enough if they're leaking. Turn them so the split faces backwards on the axle (screws running vertically), and make sure the clamps are nice and tight.
If you're leakin form teh drums, then you didn't get the seal kit on correctly or damaged i when you put it in. Tear it out and start over.
Good luck! Smile
--Harlan Ellison
cperry2704
cperry2704
Posted: Mon Dec 03, 2007 11:49 PM
thanks
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 05:38 AM
alright i took that boot off, and it looks like two of the nuts pulled through their hole on the boot right near the clamp that goes around the axle
Posted: Wed Dec 05, 2007 05:49 AM
THEY JUST NEED TO BE SNUGG,,,DONT OVER TIGHTEN!!
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 05:51 AM
does that gap need to be filled with silicone or gasket sealer, along with the bolts?
Posted: Wed Dec 05, 2007 06:03 AM
NO THERE IS A LIP IN THERE MAKE CERTAIN THE LIP IS IN THE GROVE THEN SNUG THE BOLTS TILL THE GAP IS CLOSED, IF THERE IS NO LIP, JUST SNUG BOLTS LIKE I SAID BEFORE , WERE DID YOU GET YOUR BOOT,,ARE THEY THE GOOD KIND?
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 06:08 AM
yeah they are good quality, got them at my local v-dub shop here an san diego
Posted: Wed Dec 05, 2007 06:09 AM
Smile
cperry2704
cperry2704
Posted: Wed Dec 05, 2007 06:20 AM
while im here, what is the easiest way to get some space, so i can slide the boot around the axle?
Posted: Wed Dec 05, 2007 06:23 AM
JACK IT FROM THE SHOCK TOWER!
fatalifeaten
fatalifeaten
Posted: Wed Dec 05, 2007 09:42 PM
what jamesr said. Smile
--Harlan Ellison
16 DerekT 4952 Axle's needed
 Sat Dec 10, 2016 07:17 PM
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 4677 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 3058 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion another rear axle question 3 onthefarm 3022 another rear axle ques...
 Sat Aug 04, 2012 05:22 AM
onthefarm View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 61 bug swing axle to 67 bus swing axle help 5 pussiwillow 5304 61 bug swing axle to 6...
 Fri Jan 28, 2011 07:39 AM
Gettinsomeair View latest post
