AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Chirco roll cage for Super got a question....
Users browsing this topic:
None
Author |
Message |
jeepnut7261
Post subject: Chirco roll cage for Super got a question....
Posted: Fri Nov 30, 2007 12:06 AM
OK, I have a 74 Super, yes I know it's a bear to Baja, but I am going to try anyway.
SO, can I use the 6 point roll cage advertised here from chirco to use as a base to build a tube front? Or do I need something heavier?
I've built stuff for Jeeps, so I can bend pipe and weld (grind too) and I am thinking of just copying a rail front end (sort of) to put an regular beetle front axle on.
So, any suggestions? (besides getting another year)
_________________ Flat learning curve............
DOGLESS HIPPIE!!!
oh, wait, I have a dog, uhh, or maybe cat, uhh, goldfish???? I don't think it's one of the kids....
+3
Post subject: Re: Chirco roll cage for Super got a question....
Posted: Fri Nov 30, 2007 02:18 AM
jeepnut7261 wrote: |
So, any suggestions? (besides getting another year) |
probable a type-o...you wrote pipe...you mean tubing correct ?
sorry dont have a answer for your question.
+10
Posted: Fri Nov 30, 2007 02:19 AM
I think it would be a good base. If you do that then you could easily convert the front end.
jeepnut7261
Posted: Fri Nov 30, 2007 02:32 AM
1FASTHOE wrote: |
sorry dont have a answer for your question. |
Yep, tubing.
DOGLESS HIPPIE!!!
+35
Posted: Fri Nov 30, 2007 04:32 AM
You should be able to use the cage. The only problem that you might run into is the front hoop hitting the dash, but it may not. The rear will fit for sure.
_________________ Bugzyla Fabrication
jeepnut7261
Posted: Fri Nov 30, 2007 04:37 AM
Front hoop? Do you mean the dash bar? Hey, cut and bend, then weld again!!
I am going to take the body off the pan this weekend, so I will have a better idea about reinforcing the pan for attachment too.
DOGLESS HIPPIE!!!
vwbill
+1
Posted: Fri Nov 30, 2007 11:57 PM
Some where I read supers bodys differ from standard bug by 1" between front fender and door. From door back they should be the same. Chassis differ at frame head. Not sure how your curved window and padded dash measure up though.
William
+35
Posted: Sat Dec 01, 2007 12:54 AM
71 & 72 supers are the same from the dash back. The 73 & up im not so sure on the cage clearing the dash, but they do take the same doors so it might just clear.
tigerextra
-1
Posted: Mon Dec 03, 2007 12:36 AM
an easier way to fab the front end for the link pin is to cut the McPherson crap off then weld on a link pin frame horn. thats what i did and am planning to have Bugzyla and gang strengthen all that into the cage. just make sure its all square. you can even give yourself another six inches or so in length depending onh your preference. . let me know if you have any questions!
[img]  [/img]
_________________ "i dont make the rules, i dont even follow them, i just enforce them"
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
jeepnut7261
Posted: Mon Dec 03, 2007 12:28 PM
tigerextra wrote: |
[img] [/img] |
OK, first question...
I have seen where others online have done that, where can I find a link pin pan?
DOGLESS HIPPIE!!!
+35
Posted: Mon Dec 03, 2007 03:29 PM
You can buy just the frame head from Chirco
www.chircoestore.com/c...9rvi7uh6q0
tigerextra
-1
Posted: Mon Dec 03, 2007 06:02 PM
this is a very simple and effective way of transforming your super into an IRS/link pin baja. just MAKE SURE ITS SQUARE! i cant stress that enough... also good welds are a plus. note in the pic that i drilled half inch holes in the frame head BEFORE i mounted it, then "spot welded" the holes to the pan. dont forget to grind and clean all contacting metal for good penetration. i also beefed up all contacting ends with a few thick welds for structure. also it is imperative that you strengthen the beam to the cage, not that this isint already very strong if you do it right, but you can never be too strong! good luck
>ask questions when you are unsure, cut once and measure fifteen times.
all 6 of us agree!!
+10
tigerextra
-1
Topics |
Replies |
Author |
Views |
Last Post |
Projects and Builds
3" Body Lift, Class 11 cage, Warrior Beam w/ 10" towers, 3x3
Go to page:
1, 2 ]
25 |
Kreed |
26743 |
3" Body Lift, Class 11... Tue Apr 10, 2018 02:26 PM Kreed  |
Events and Get Togethers World Wide
Official 2016 Hassaympa PlayDay Roll Call!!
Go to page:
1, 2 ]
18 |
Dirtjunkie |
6908 |
Official 2016 Hassaymp... Tue Nov 08, 2016 02:49 AM MuddyPruett69  |
ROLL CALL - HASSAYAMPA
Go to page:
1, 2, 3 ]
42 |
wideopenmotorsports |
14797 |
ROLL CALL - HASSAYAMPA Sun Nov 08, 2015 03:14 AM Azdrtdog  |
Baja Bug Modification question
4 |
Ailill |
8110 |
Baja Bug Modification ... Mon Apr 13, 2015 04:07 AM Ailill  |
Lifting a super beetle front end
1 |
72sbbaja |
2227 |
Re: Lifting a super be... Wed Jul 02, 2014 04:42 PM wideopenmotorsports  |
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
