Visitors: 142
Total: 142
20: Event Calendar
21: Home
22: Home
62: Event Calendar
64: Event Calendar
68: Home
120: Event Calendar
139: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cam with high ratio rockers?
nube_w_1970baja
nube_w_1970baja
Post Post subject: cam with high ratio rockers?
Posted: Fri Nov 30, 2007 05:59 AM
so, i'm guessing that you need to change the cam to modify the engine characteristics, right?
or is it that you can change the rockers to 1.10, 1.25, or 1.40 to get more power?
sorry, kind of spacey, waiting for parts to be all ready:)
unlimited
unlimited
Post Post subject: Re: cam with high ratio rockers?
Posted: Fri Nov 30, 2007 02:53 PM
Answer to ? 1 is yes. The cam is the brain. Higher ratio rockers only effect one aspect of the cam and that is lift. They have no effect on cam timing, lobe center, or duration. It is an acceptable method of getting a little more out of your cam. The trade off for the benifit is increased valve guide wear. They tend to side load the valve. Things to check for when increasing rocker ratio, coil spring bind, retainer to guide clearance, valve to piston clearance, and confirm your rocker arm geometry(pushrod length). Good resource book is How To Hotrod Your VW.
Dirt's for racin, asphalt for gettin you there!
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 2555 Re: Need Help....Dash ...
 Thu Nov 10, 2011 06:55 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Jumped it way to high!
21 JumpinBruceB 7692 Re: Jumped it way to h...
 Mon Sep 08, 2008 01:26 AM
JumpinBruceB View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Anyone going to Flagstaff for the High Altitude VW Kampout? 12 biblethumpncop 3997 Re: Anyone going to Fl...
 Wed Aug 06, 2008 04:57 AM
No new posts Events and Get Togethers World Wide Anyone going to Flagstaff for the High Altitude VW Kampout? 2 biblethumpncop 2267 Re: Anyone going to Fl...
 Sun Jul 27, 2008 11:34 PM
biblethumpncop View latest post
No new posts VW Volkswagen & Baja Bug General Discussion high (lol( 5 i gained rank!!!!!!!!!!!!!!
18 blood_red_baja 5301 Re: high (lol( 5 i gai...
 Tue Mar 04, 2008 03:53 PM
blood_red_baja View latest post
