Latest: Smokey4
Overall: 3593
Visitors: 100
Total: 100
40: Event Calendar
52: Event Calendar
53: Pictures
61: Pictures
84: Event Calendar
99: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cam with high ratio rockers?
nube_w_1970baja
nube_w_1970baja
Post Post subject: cam with high ratio rockers?
Posted: Fri Nov 30, 2007 06:59 AM
so, i'm guessing that you need to change the cam to modify the engine characteristics, right?
or is it that you can change the rockers to 1.10, 1.25, or 1.40 to get more power?
sorry, kind of spacey, waiting for parts to be all ready:)
unlimited
unlimited
Post Post subject: Re: cam with high ratio rockers?
Posted: Fri Nov 30, 2007 03:53 PM
Answer to ? 1 is yes. The cam is the brain. Higher ratio rockers only effect one aspect of the cam and that is lift. They have no effect on cam timing, lobe center, or duration. It is an acceptable method of getting a little more out of your cam. The trade off for the benifit is increased valve guide wear. They tend to side load the valve. Things to check for when increasing rocker ratio, coil spring bind, retainer to guide clearance, valve to piston clearance, and confirm your rocker arm geometry(pushrod length). Good resource book is How To Hotrod Your VW.
Dirt's for racin, asphalt for gettin you there!
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 2667 Re: Need Help....Dash ...
 Thu Nov 10, 2011 07:55 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Jumped it way to high!
21 JumpinBruceB 7876 Re: Jumped it way to h...
 Mon Sep 08, 2008 01:26 AM
JumpinBruceB View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Anyone going to Flagstaff for the High Altitude VW Kampout? 12 biblethumpncop 4097 Re: Anyone going to Fl...
 Wed Aug 06, 2008 04:57 AM
No new posts Events and Get Togethers World Wide Anyone going to Flagstaff for the High Altitude VW Kampout? 2 biblethumpncop 2332 Re: Anyone going to Fl...
 Sun Jul 27, 2008 11:34 PM
biblethumpncop View latest post
No new posts VW Volkswagen & Baja Bug General Discussion high (lol( 5 i gained rank!!!!!!!!!!!!!!
18 blood_red_baja 5519 Re: high (lol( 5 i gai...
 Tue Mar 04, 2008 04:53 PM
blood_red_baja View latest post
