Visitors: 106
Total: 106
03: Event Calendar
83: Home
85: Links
95: Event Calendar
97: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Dumb questions
Dumb questions
Sample
Sample
Post Post subject: Dumb questions
Posted: Sat Nov 10, 2007 06:09 AM
All questions are about the '66 Baja I just bought
#1
How do you remove the fuel level sending unit from the top of the gas tank?
#2
Why doesn't the driver side door have an interior door handle, not even a place where one used to be?
Thanks,
Chris
StinkBug333
StinkBug333
Post Post subject: Re: Dumb questions
Posted: Sat Nov 10, 2007 06:27 AM
#1 is it a stock tank? there is a lock ring that goes around where the sender is mounted to the tank. take a screw driver and a hammer and tap it LIGHTLY and it should turn. then pull it up and out.
#2 some one put in a interior pannel and was to lazy to poke the holes through and srew the handle back on.....
Or i could be wrong. havent delt with stock stuff in a little while.
Best of luck
If your gonna be Dumb
YOU BETTER BE TUFF!
MWDesigns
MWDesigns
Posted: Sat Nov 10, 2007 07:48 AM
#2 Q... I agree with StinkBug, some one probably was too lazy (or thought it looked cool) and didn't cut out the hole.
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Posted: Sat Nov 10, 2007 02:26 PM
#1 If you cant see 5 screws on the top of the sending unit, it is the old cable style sender. In that case just stick a small screw driver in the hole where the cable comes out of and gently pry it up. This will reveal where the cable hooks up and the 5 screws that hold it in the tank.
Sample
Sample
Posted: Tue Nov 13, 2007 06:14 AM
Thanks guys.
It looks like the door was never made to be opened from the inside. Very odd.
I have another question:
Are there aftermarket pedals that are spaced wider apart? Or has anyone modified the stock pedals further apart? I seem to have big feet.
StinkBug333
StinkBug333
Posted: Tue Nov 13, 2007 06:32 AM
EVERY BODY has big feet in a bug. you will soon learn how to use this to your advantage if youve never owned a bug before. Youll learn how to push the clutch in and aply the brake while reving the engine at the same time (To keep it from stalling) . A unique thing iv never experienced in any other vehicles. Hope those big feet Are attached to strong legs cause at one time or another you WILL push that bug. Thats where the love comes in...
Happy buggin!!!
YOU BETTER BE TUFF!
Posted: Tue Nov 13, 2007 07:12 AM
You need tp get a door handle in there just for safety reasons.
MWDesigns
MWDesigns
Posted: Tue Nov 13, 2007 07:44 AM
Sample wrote:
Thanks guys.
Can you get some picts of the door, with and without the door panel. I seems very odd that you would not have any type of handle. The area behind the door panel isn't totally obvious where the handle goes if someone has removed the small bar that connects the latch to the handle. Picts would help to point out where it should go.
Graphic Designer,
Army OIF Veteran
MWDesigns
MWDesigns
Posted: Tue Nov 13, 2007 08:31 AM
I took some pictures of my door. Hope this helps..
Graphic Designer,
Army OIF Veteran
Sample
Sample
Posted: Tue Nov 13, 2007 10:20 AM
I will get some pics in the morning, but I am pretty sure that is not there.
Posted: Tue Nov 13, 2007 01:13 PM
If its a 66 then is will have a flat bar instead of the round rod. If you are missing that piece, let me know I may have it.
MWDesigns
MWDesigns
Posted: Tue Nov 13, 2007 05:14 PM
Shocked Is there anything you don't have Daryll? Laughing
Graphic Designer,
Army OIF Veteran
Sample
Sample
Posted: Tue Nov 13, 2007 05:20 PM
It is a 66.
Here are the pics.
MWDesigns
MWDesigns
Posted: Tue Nov 13, 2007 05:38 PM
Graphic Designer,
Army OIF Veteran
Posted: Tue Nov 13, 2007 06:19 PM
Cool Cool A million dollars, at least not yet Cool Cool
Sample, is the latch still there that keep the door closed? I know I have the rod and actuator that the door handle goes on, but I dont think I have any drivers side latches.
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 4331 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5063 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 2034 Tow Bar questions
 Mon Nov 16, 2015 02:45 PM
No new posts New Members New Guy Questions 6 Apoc 3881 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 7794 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
