Visitors: 135
Total: 135
40: Pictures
50: Pictures
55: Pictures
74: My Account
77: Event Calendar
113: Event Calendar
125: My Account
133: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- is the big benefit of 3x3's?
nube_w_1970baja
nube_w_1970baja
Post Post subject: is the big benefit of 3x3's?
Posted: Tue Nov 06, 2007 02:30 AM
what's with the 3x3 rear irs setup? is it for more travel on the rear end or better control when you are really hitting it hard?
good times. Smile
Post Post subject: Re: is the big benefit of 3x3's?
Posted: Tue Nov 06, 2007 03:18 AM
more travel if your running coilovers, and a wider stance for stabilty...
Hutch
Hutch
Posted: Tue Nov 06, 2007 04:35 AM
Longer wheel base should also make for a less buckboard ride on washboard roads and such.
VW Newb and having a blast!
1972 Baja bug, smokin' primer gray paint, with flaming skull stickers.
1977 IH Scout SSII F&R Dana 44's, R locker, 35" BFG MT. Orange to go faster.
Posted: Tue Nov 06, 2007 07:03 PM
And they look BITCHIN'. =)
Posted: Wed Nov 07, 2007 01:11 AM
good times. Smile
Yes, and yes. And the travel is not just with coil overs. They put the centerline of the wheel 3 inches further from the pivot point and 3 inches wider track.
Basic math shows the longer an object is from the pivot the further the travel at the same degrees of movement. Sooo 12-14 inches of travel where 8-9 was before. Being wider allows for less angle on the cv joints at the same point.
There are some drawbacks to 3x3's... You need a cage to mount the shocks to, you usually use 930 cv joints and mathing stub axles, flanges and axles, if you stay with torsions, you need to go thicker to deal with the increased leverage the arm/wheel creates. Figure 900-1200 unless you go with race stuff, then 1500 and up.
but the real reason to run them is they look cool and you can say "yeah I have 3 x 3's and 930 cv's...just kidding.
Hope that helps. Maybe Daryll will post some pictures of what he installed on my car for reference.
Posted: Thu Nov 08, 2007 03:15 AM
StinkBug333
StinkBug333
Posted: Thu Nov 08, 2007 03:44 AM
bigest benifit? More travel? Beter shocks? Beefer Driveline? It all adds up to DRIVE FASTER!!!!
OOh yeah and it looks bitchen.
and Cause 3" Wheel spacers are kinda dangerous....
If your gonna be Dumb
YOU BETTER BE TUFF!
No new posts VW Volkswagen & Baja Bug General Discussion Proposed AzBaja Club Baja Build to Benefit JDRF.. 13 bajawarrior 5893 Re: Proposed AzBaja Cl...
 Wed Feb 18, 2009 02:24 PM
No new posts Events and Get Togethers World Wide Benefit Car Show, Open to ALL makes and models
Proceeds will benefit Sunshine Acres Childrens Home
0 BugZyla.com 1463 Benefit Car Show, Open...
 Tue Jan 13, 2009 02:56 PM
