Visitors: 71
Total: 71
01: Home
03: Memberships
05: Pictures
08: Event Calendar
13: Event Calendar
21: Event Calendar
23: Event Calendar
31: Event Calendar
39: Event Calendar
68: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- another two part question from the nube...
nube_w_1970baja
nube_w_1970baja
Post Post subject: another two part question from the nube...
Posted: Mon Nov 05, 2007 07:33 AM
the carb that i have right now seems like it has a really lame set-up. the mixture screw faces the fan housing and the adjuster screw has vacuum ports surrounding it.
so, i was wondering, what carb is best to run for for a 1641 that can be adjusted easily and is relatively maintenance free?
StinkBug333
StinkBug333
Post Post subject: Re: another two part question from the nube...
Posted: Mon Nov 05, 2007 03:51 PM
i had one of those kadron or solex ones on my 1600 and it ran about as good as i could get it, plus it had a electric choke. The best part is their fairly easy to get ahold of...
If your gonna be Dumb
YOU BETTER BE TUFF!
fatalifeaten
fatalifeaten
Posted: Thu Nov 08, 2007 05:27 AM
34 pict 3, or a 2 bbl weber progressive Smile
--Harlan Ellison
nube_w_1970baja
nube_w_1970baja
Posted: Thu Nov 08, 2007 08:21 PM
the carb i have now is a weber to 2bbl. not sure if progressive or not. the adjuster screw faces the dog house and has (i think) 3 vacuum ports surrounding it. so, there is not really an easy way to adjust it.
also, the fuel boss wiggled out one day as i was driving down the road. when i came to a stop there was gas all over the HOT exhaust. i beat it back in and kept going.
i would like to stick with a single carb though. maybe go to duals down the road, but which setup gives more torque, if any?
thanks for all the info:)
No new posts Projects and Builds looking for a part. 0 Dalton 1833 looking for a part.
 Thu Jun 04, 2015 03:26 PM
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 6198 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2130 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 4532 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 2857 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
