Latest: ddbug11
New Yesterday: 2
Overall: 3596
Visitors: 124
Total: 124
53: Contact Admin
67: Pictures
72: Event Calendar
81: My Account
93: My Account
97: Pictures
105: Garage
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Gas tank vacuum not allowing gas to go down?
Billy
Billy
Post Post subject: Gas tank vacuum not allowing gas to go down?
Posted: Sun Nov 04, 2007 01:16 AM
Baja sits for 2 weeks go to start it upa nd it has lots of trouble on many tries. Check gas level in poly gas tank and try starting it with the cap loose. With this tank, does the vacuum that developes in the tank prevent gas flow after periods of sitting? Because after we tried it again with the cap on loose it fired right up.
Post Post subject: Re: Gas tank vacuum not allowing gas to go down?
Posted: Sun Nov 04, 2007 03:24 AM
buy a vented gas cap... Wink
Posted: Sun Nov 04, 2007 03:32 AM
I had the same problem with my baja, it wouldnt run with a vacuum on the tank, replaced the cap with a vented one and it was fine.
Posted: Sun Nov 04, 2007 05:07 AM
SOME OF THE OLDER TANKS(FILL INSIDE THE TRUNK STYLE) HAS A VENT IN THE FILLER NEXT NEXT TO THE CAP ,ALSO HAS A SMALL HOSE GOING TO THE GROUND FOR A VENT,,,,MY 65 HAS THIS,,
Billy
Billy
Posted: Sun Nov 04, 2007 11:02 PM
Ok great thanks guys I shall replace it.
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 2017 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Help Needed --> Gas Tank Safety!! 2 jk97 2642 Help Needed --> Gas Ta...
 Wed Jul 13, 2011 06:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion stupid leaking gas tank gaskets... 3 Brettucks 3370 stupid leaking gas tan...
 Fri Aug 07, 2009 10:38 PM
Brettucks View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Thinking about getting a Long Range 16 Gallon Fuel Tank 10 siacs 4653 Re: Thinking about get...
 Sat Oct 18, 2008 03:43 AM
siacs View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Baja gas tank behind back seat 13 flyboy942003 12220 Re: Baja gas tank behi...
 Wed Jul 09, 2008 05:06 AM
