Latest: xbluegto
Overall: 3573
Visitors: 224
Total: 224
26: Event Calendar
76: Event Calendar
84: Pictures
94: Event Calendar
108: My Account
123: My Account
172: Baja Forums
185: Event Calendar
186: Baja Forums
190: AMAZON.com
191: Baja Forums
194: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
211: Baja Forums
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
215: Baja Forums
216: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- My baja bug project rear end question ?
DRUMMOND
DRUMMOND
Post Post subject: My baja bug project rear end question ?
Posted: Thu Nov 01, 2007 07:59 PM
I just finished the rear of my baja.. I AM SO HAPPY right now !! ( BUT )
Hear is the problem I think I want to cut it up and make it wider now before I do brake lines etc.
What are the pros and cons and how wide is too wide ?
How wide is a stock torsion housing ?
What will I gain from doing this ?
Is that to many questions ? LOL !!!
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
MWDesigns
MWDesigns
Post Post subject: Re: My baja bug project rear end question ?
Posted: Thu Nov 01, 2007 08:12 PM
Did you use the 3X3 arms?
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
DRUMMOND
DRUMMOND
Posted: Thu Nov 01, 2007 08:42 PM
YES here is a photo of what we have now.
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
MWDesigns
MWDesigns
Posted: Thu Nov 01, 2007 10:47 PM
I'm no expert on the subject but I would think the setup you have now should be more than sufficient. If it's a Baja you shouldn't really need to be any wider. Your setup look good, I wouldn't change it.
Some of the other guys may have some suggestions.
Graphic Designer,
Army OIF Veteran
Posted: Fri Nov 02, 2007 02:26 AM
I would stick to what you have right now, we are building a baja right now with 5x5s and I think its a bit much.
By the way, Nice sticker!!!!!!!!! Cool
Posted: Fri Nov 02, 2007 02:38 AM
I,VE SEEN THAT CAR SOMEPLACE !!!!
DRUMMOND
DRUMMOND
Posted: Fri Nov 02, 2007 02:58 AM
" By the way, Nice sticker!!!!!!!!! "
THANK YOU !!!
Daryll you do good work. I am trying to finish the car so everyone can see the graphics.
This is the problem that I am having but I did not know about it until I got everything together..
I had to use very short axles 18 1/2 that's relay to short for my set up.
I assembled everything and can only get 10 inches of travel. I need to get some stops in and limit straps on so I am looking at like 8 inches max.
Hears what I am thinking... You have more experience than me so I wanted to know what you think !
What if I extended the rear torsion housing 3-6 inches on each side for a total of 6-12 inches ((( depending on what I can get in the garage door )))
Would that give me any more travel ?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Fri Nov 02, 2007 03:49 AM
No, Extending the torsion will only give you width, not travel. If you want more travel you will need longer arms and longer coil overs.
DRUMMOND
DRUMMOND
Posted: Fri Nov 02, 2007 04:02 AM
I have 16in travel 2.5 KING coil overs.
Its the cvs that are limiting my travel.
As the axle gets longer the angel will decrease and allow me to lower the a arm some right...
P. S. stop me if I am BUGging you !
I have another question for you.
Do you fab front hoops I have KING 12in
travel coil overs ?
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Fri Nov 02, 2007 04:59 AM
What CVs are you running? Whats the angle on the axle at full droop? We can do shock hoops, but the die I have is a 6" radias so the hoops wont be a very tight bend.
Posted: Fri Nov 02, 2007 05:19 AM
I think your axles may be too short.
DRUMMOND
DRUMMOND
Posted: Fri Nov 02, 2007 05:29 AM
I am running the 930s
the angle is 28 at full drop
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Fri Nov 02, 2007 05:31 AM
I just talked to scott and he said there is a T-1 trans and the torsion is stock length, with 3x3 arms you should be in the 20 1/4 range on the axle length. It looks to me like the axles are too short and the c-clip is bottoming out on the CV joint when you let the arm droop. Try pulling a c-clip off and see it the droop gets better. Also make sure the heim joint isnt in a bind, and the bolts sticking out of the heim plate are not contactng the arm.
Posted: Fri Nov 02, 2007 05:33 AM
Is that pic above at full droop? If so that doesnt look anywhere near 28 degrees.
DRUMMOND
DRUMMOND
Posted: Fri Nov 02, 2007 05:42 AM
the pick is at full drop the axle is hitting the bottom of the inner flange and the top of the outer flange
you are right on the nose ! That's my delima !
21 and 1/4 is for t-1 to 3x3 w930
19 1/4 for bus
Ordered all of thees axles
the one that fit was the 18 1/2
I have the 19 1/4 in right now I think it is to big I don't think I will be able to get my rear alignment right without machining some off.
At full drop I can move the axles back and forth at least an inch.
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
4 Admin_AzBaja 5713 Baja Bugs on Wiki need...
1568 mufasavnvmc 903759 Re: what did you do to...
285 MusicManiac 218999 Re: Baja sightings
0 Northmountainauto 268 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1520 Baja hiding in Chandle...
