Visitors: 121
Total: 121
08: Event Calendar
22: Home
41: Event Calendar
45: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- more power and where?
nube_w_1970baja
nube_w_1970baja
Post Post subject: more power and where?
Posted: Sat Oct 27, 2007 01:36 AM
i bought a 1970 baja bug a few months ago and i'm finally starting to work on it. the motor sounded funny and puffed during start up. felt like it had enough power driving it down the road, even loaded with 4 guys in it...
tested for spark, adjusted the valves, adjusted the carb, still nothing
thought it might be the #3 cylinder.
took off the heads (factory) and to my demise, a hole that went from the cylinder chamber to one of the head studs:(, and when disassembling, all of the head studs were finger tight. so i have to get new heads, no biggie.
so, what i want to know is: should i go with the 1600 heads for more reliability= less power or 1641 heads for more power=less reliability?
or can i get 1600 heads and change something else in the head for more power?
most of my driving is on the road, some packed sand/dirt roads. no dunes, mud or drag racing...
any help would be greatly appreciated:)
Post Post subject: Re: more power and where?
Posted: Sat Oct 27, 2007 02:54 PM
my vote is always more power Wink
BajaMan87
BajaMan87
Posted: Sat Oct 27, 2007 07:06 PM
Cam lifters and rockers. myabe 1641 heads it wont be that much less reliable. depending on how you drive but from what your exclaiming it'll be fine.
Drive it like you stole it.
1972 VW Super Beetle BAJA
Posted: Sat Oct 27, 2007 11:13 PM
1600 and 1641 use the same heads.
BajaMan87
BajaMan87
Posted: Mon Oct 29, 2007 02:59 AM
ok then 1700cc heads Razz
fatalifeaten
fatalifeaten
Posted: Mon Oct 29, 2007 05:45 AM
Heads are bored for cylinder diameter. Stock heads will fit both 1600 and 1641 cylinders because they're machined from the same outside diameter thickness cylinder. It's the inside diameter that changes. If you want to wake your heads up, you're not going to be changing the bore size, you're going to be doing things like porting and polishing, playing with the valve diameters, changing the rocker geometry, adjusting the capacity of each individual cylinder (IE changing from a 60cc head to a 65cc head as an example). You can spend a LOT of money on head work but it's one of the single most important things you can do to really wake up a motor.
"1700 cc heads" isn't really accurate. If you go to a head with a larger bore, you need to go to a piston and cylinder that are also that bore (IE 90.5mm sets that would bump you to a 1776 cc motor), or you're going to be hosed and the motor will run like someone shot it, if at all. As far as reliability goes, it really depends on how hard your run the car and how good your head builder was/is. If they know what they're doing and do a good job, worked heads can be as reliable as stock, of not more. If they're fly-by-night or just importing junk from china, your mileage may vary. There are several good companies out there that sell "upfitted" heads for a variety of applications from mild to wild, and you can usually find a set that suits your budget.
Hope that helps Smile
--Harlan Ellison
BajaMan87
BajaMan87
Posted: Mon Oct 29, 2007 03:38 PM
VERY INSIGHTFUL!!!!!! I didnt know what you could do to a VW head.
nube_w_1970baja
nube_w_1970baja
Posted: Thu Nov 01, 2007 08:56 AM
thank you for all the info. Smile
with the cam lifters and rockers/rocker geometry, what are the more common sizes?
and where is the best places to go in the phoenix area?
anything you guys have would be greatly appreciated:)
good times
ridinthedunes
ridinthedunes
Posted: Thu Nov 01, 2007 05:54 PM
Setting up rocker geometry isn't a power adder, it's just what you have to do when building an engine.
You should really talk to a local engine builder if you can. You should set the engine up as a package, but if you're just looking to get new heads and not pistons/cylinders, I'd say just get stock valved heads and have a reputable shop do some light port work on them, maybe raise the compression a "little" and put some carbs on it.
If you want to go bigger you can go anywhere from 1641 to 1915cc by getting a piston/cylinder set, after gettting past the 1700cc mark you can start justifying gettting larger valved heads (40x35 probably as big as you'd wanna go)....but then you really should pull it apart and get a larger cam that fits your driveing style..........and the list goes on....
Posted: Thu Nov 01, 2007 06:05 PM
Here is a list of parts for a motor I am building right now. This is a fairly inexpensive build for a 1915cc thatnks to the Chirco kit
www.chircoestore.com/c...ts_id=2621
We went with the engle 110 cam on this motor.
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 6653 Cheap DIY electric pow...
 Fri Nov 06, 2015 02:07 AM
No new posts New Members I don't have VW power, is that okay? 7 AZBadseed 5084 Re: I don't have VW po...
 Wed Sep 07, 2011 11:52 PM
AZBadseed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion PROJECT FLOWER POWER!
39 crickifur 15743 Re: PROJECT FLOWER POW...
 Sat Dec 04, 2010 06:33 AM
No new posts VW Volkswagen & Baja Bug General Discussion baja power troubles 10 bajaboy 5213 Re: baja power trouble...
 Mon Sep 15, 2008 07:13 PM
70bug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion no power 10 blood_red_baja 2949 Re: no power
 Thu Mar 06, 2008 07:41 AM
Preston View latest post
