Visitors: 103
Total: 103
05: Event Calendar
24: Pictures
47: Pictures
59: Event Calendar
82: Event Calendar
86: Pictures
93: Pictures
101: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- can someone help
can someone help
kawsquid
kawsquid
Post Post subject: can someone help
Posted: Fri Oct 19, 2007 04:26 AM
hopefully someone can help me with this problem I just recently bought a 71 baja awsome car but the person i bought the car from installed a bus box in it and i cant get it to shift into any gear the shifter rod is on top of the trans hump he also put in sway away axles and the left axle is broken hopefull sone one can help me out with some advise Sad Question
BajaMan87
BajaMan87
Post Post subject: Re: can someone help
Posted: Fri Oct 19, 2007 03:52 PM
well i dont know much about the swap from bus to bug but here goes. it wont go into any gear? have a friend sit inside the car and try to put into gear while your under the car. see if the linkage is bending or shifting in any way to keep it from goin into gear if nothing is wrong there. disconnect the shifter and try to put it into gear. let me know what happens. I dont know what to tell you and the axle except to replace it.
Drive it like you stole it.
1972 VW Super Beetle BAJA
MWDesigns
MWDesigns
Posted: Fri Oct 19, 2007 05:27 PM
Under the car won't help... you need to be IN the car. If the your car has the bus trans and your shifter is on top of the tunnel then there should be a big hole cut inside the car where the nose cone of the trans comes through. You might try to move the car b hans slightly while someone tries to put the car in gear. If the axle of the car was broken from abuse then you might also have some internal trans breakage, might also be the problem with not shifting.
Bugzyla always has some good info...
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
vwbill
vwbill
Posted: Fri Oct 19, 2007 06:01 PM
Some, maybe all, bus transaxles have the flanges offset from centerline and require a different length axle on one side than the other. I know this existed on 68-71 not sure of later units. There should be about a 1/4” difference if I remember right. Double check that your axles are the right length.
Try disconnecting your shift linkage and sift the trans by hand. This will eliminate internal and external problems.
William
kawsquid
kawsquid
Posted: Sun Oct 21, 2007 05:11 PM
hey guys thank you for all your great info I got the car to run exellently afterwords its pretty cool i took the car to have it checked out they told me the car has a 2333 engine i have no idea what this means but the car has mega balls and will smoke the 31in tall tires on the rear but you guys are awsome hopefully i will get some pics to post on here i think i'm going to paint the car lime green like a kawasaki tell me what you think
vwbill
vwbill
Posted: Sun Oct 21, 2007 06:59 PM
2333cc is the engine size. Largest type one from factory was 1600 and type four went to 2000, so you have a large performance engine in there.
William
MWDesigns
MWDesigns
Posted: Mon Oct 22, 2007 01:56 AM
2333 means HOLY SH@T!!!!!!! Surprised Your passengers will most definitely want to take advantage of your "Oh Shit" handle. Shocked
Have fun and remember to keep it rubber side down!
Graphic Designer,
Army OIF Veteran
Posted: Mon Oct 22, 2007 07:34 AM
Shocks.
Pegs.
LUCKY!!!!!!
Have you ever taken' it of any sweet jumps?
MWDesigns
MWDesigns
Posted: Mon Oct 22, 2007 05:12 PM
it's a sledge hammer...
Graphic Designer,
Army OIF Veteran
