Visitors: 109
Total: 109
13: Event Calendar
14: Home
20: Event Calendar
44: Home
86: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Cutting the top to my '68
mongeey
mongeey
Post Post subject: Cutting the top to my '68
Posted: Tue Oct 16, 2007 02:36 AM
I'm going to be cutting the top off of my '68, but before I do, I need to put the roll cage in. Should I get a 4 point Cage (bolt in) or a Weld in 6 point?
zx10r203
zx10r203
Post Post subject: Re: Cutting the top to my '68
Posted: Tue Oct 16, 2007 07:09 PM
i would say a weld in 6 point. Should add the strenght back that will be taken off with the top. The 4 point would basically from my point of view be just to reinforce the roof. The 6 point will connect the front and rear of the car.
Posted: Wed Oct 17, 2007 12:47 AM
Welcome back, hadn't seen a post from you in awhile.
Go with the 6 point, and maybe add a couple of extra tubes to tie it together.
Posted: Wed Oct 17, 2007 03:04 AM
If yuo are cutting the top off, you will need braces running from the cage th the A and B pillars to keep the flex down on the body. I agree with the extra tubes. You should add tubes where the rear down bars mount to the rear cargo tray down to the frame horns, and also bars from the front hoop the the front beam.
No new posts VW Volkswagen & Baja Bug General Discussion Guide for cutting up sheetmetal 6 Ravewolf 3778 Guide for cutting up s...
 Sun Jan 18, 2015 10:36 AM
No new posts VW Volkswagen & Baja Bug General Discussion cutting up your bug to baja it 4 cyberjaw4 2206 Re: cutting up your bu...
 Tue Dec 23, 2008 12:13 AM
cyberjaw4 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cutting holes for gauges 5 az350x 2839 Re: Cutting holes for ...
 Sat Jan 19, 2008 01:22 AM
VIN70 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cutting of the roof ?
16 neon99 11981 Re: Cutting of the roo...
 Fri Jan 18, 2008 05:31 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion cutting metal 11 beginnerbaja 5259 Re: cutting metal
 Sat Mar 03, 2007 07:16 PM
Billy View latest post
