Visitors: 119
Total: 119
09: Home
10: Home
11: Home
15: My Account
39: Event Calendar
42: Event Calendar
91: Event Calendar
95: Event Calendar
99: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- wiering and pant 72 Baja
robertsbajb
robertsbajb
Post Post subject: wiering and pant 72 Baja
Posted: Tue Sep 11, 2007 04:20 AM
I have a 72 Baja and the turn lights are not wired I could use some help with it and the pant is chipping how do I prevent this from happing?
Post Post subject: Re: wiering and pant 72 Baja
Posted: Wed Sep 12, 2007 03:26 AM
Welcome to the board, Robertsbajb.
Can someone chime in with some advice on where you can find a schematic???
There's several VW-oriented how-to maintenance books available. If you're new to VW ownership, you may want to invest in a couple of those. There's a TON of info available. Sorry, I don't know enough off the top of my head to be of more help!
Posted: Wed Sep 12, 2007 06:50 AM
It sounds kind of stupid but stand ant the back of your car and yank all the wire out and rebuild it your self, That is what I do and it works so much better than the stock wireing. I will try and get a wiring diagram made and uploaded.
Posted: Wed Sep 12, 2007 06:09 PM
Here is a link to your factory diagram. Previously posted by Bugzilla.
www.vintagebus.com/wir...index.html
Hope that helps.
robertsbajb
robertsbajb
Posted: Wed Oct 10, 2007 05:37 AM
thank you we juist fix it 10-9-07 at 11:34 pm it was a challenge but we did it and if know how to stope paint from chiping let me know
BajaMan87
BajaMan87
Posted: Sun Oct 14, 2007 05:04 PM
where is the paint chipping????
on the corner or rounded area. your best bet is to chip off what is flaking up, sand down the edge of the paint and put some kinda paint in place of what chipped off.
a flatter surface is a bit different. because there isnt a bend in the paint there isnt much strain which probably means that theres a bubble of air, water or rust behind it. but the way to fix it is pretty much the same.
Drive it like you stole it.
1972 VW Super Beetle BAJA
caversmoon
caversmoon
Posted: Mon Oct 15, 2007 05:33 AM
I did mine from scratch and bugzila gave me the hook on where to get wire and a fuse box.
5 Admin_AzBaja 6786 Baja Bugs on Wiki need...
1568 mufasavnvmc 999495 Re: what did you do to...
285 MusicManiac 241423 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 19 FREE VW BAJA'S
0 Northmountainauto 1530 Shop Baja
